Good evening. I have a new to me 2021 GMC Sierra 1500 at4 with around 39,500 miles. On the dic I'm getting check trailer lights. I  can dismiss the messages but my 7 pin plug does not work. I replaced it  the 2 modules above the spare  tire with no luck fixing it. I was hoping for some help before I take it to the dealer. Thank you in advance and I love this site.
Trailer lighting control module failed.
I'm betting you didn't need to replace those two modules you replaced, one likely being the trailer brake control module and the other the chassis control module.    Those two modules won't set "check trailer lights".  The trailer lighting control module does however.
Thank you for your response but one of the models was the trailer lamp control module and the other was trailer brake control module
Sorry modules. I'm about at my wits end trying to figure it out
Have you tried the truck with a different trailer or had someone connect to the trailer thats setting the message ?
What type and vintage of trailer do you have and what type of lighting does it have ?
My understanding is that if the truck doesnt receive the proper feedback from the trailer it will set a fault message. A bad ground on the trailer or a wiring issue can cause these problems. Did you test the 7 way plug on your truck before connecting the trailer ?
Just spitballing some ideas.
Did you check the fuses for the lighting control module?  Fuses 46, 63, 74 and 82 in the underhood fuse block.
Also, check your trailer receptacle on the truck for corrosion on the terminals.
Edited by newdude
Make sure trailer light wiring matches truck. The 7-way trailer light receptacle on our trucks is wired for RV. Some utility trailers use a different 7-way wiring pattern.
Check your plugs  - Truck & Trailer make sure there clean, Also clean the hitch ball ( Rusted).  Or have a freind try his truck to your trailer .
I have a 2019 chevy silverado LTZ and having the same issues. Taken to 2 different dealerships and all they found was a blown 30 Amp fuse. Something is making it blow. 2nd dealership had my trailer with the truck for a week and couldn't figure it out. After I brought it home, no lights on trailer, a friend tested my plug on my truck and the neg pin was showing a positive charge he reset it and it showed just a negative. All the lights worked on the trailer then. 2 weeks later I hook up trailer and freaking nothing. Trailer works fine on other vehicles so it's not the trailer. Anything I hook to it I get same results. I'm ready to take it back to the dealership.
This is certainly not what we like to hear, Kastine64.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Chevrolet Silverado's trailer lights not working properly. To do so, please send an email to [email protected] with ATTN: Kastine64/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Edited by GMCustomerService
  • 9 months later...
Hello, I have the same problem. Were you ever able to get this resolved?
I was able to resolve the issue to check trailer lights when I was not connected to a trailer by changing 30 AMP fuse #74 TIM. I hope I save you some time.
Edited by heavyGMC
  • 4 months later...
WOW - GMs standards for quality sure have sank over the years. Bad enough my 2021 Sierra X-31 has the upgraded BOSE system in it where the rear speakers barely produce sound even when faded to the rear, GM knows of this flaw and we just have to live with it, but I too have trailer light error messages coming across indicating my left lights are not working and/or the brakes lights on the trailer is not working. This only happens when it is raining out and it doesn't matter if it is with my small cargo/enclosed trailer or my open trailer I get.the same messages. Once there was a code so the dealership set an appointment and then when I brought it in, they said the code automatically clears out if the issue clears out. So it continues to happen and I took photos only to have them tell me unless they can duplicate, there is nothing to be done. This is a serious hazard that can result in an accident if not remedied and my truck is factory equipped with all the towing equipment including the brake controller. This same thing never occurred with my 2019 GMC Canyon that I traded in on this 2021 GMC Siera... All the common denominator is something is wrong with this trucks factory trailer light wiring... What to do???
Edited by Daddy-Butter
Typos fixed and add photo
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
