2023 silverado 2500 high country gas....did my first oil change and chunk of metal was sitting at bottom of pan....1/4 inch long and 1/8 in wide and jageed like a spear.......had a hard down shifts into 1st gear but figured truck was learning my driving.....cpl were pretty hard but has since smoothed out...4500 miles
Other than that no weird noises and drives normal
It is big chunk of aluminum it looks like it sheared off a gear or something, I can post a pic tonight but prolly chevy won't do anything unless truck isn't running right or valid driving noise or issue am guessing......
Just took me back as I don't get paranoid or freaked easily.....abd usually wait for weird things to sort out b4 I take it serious.....just can't imagine this much metal off a part can be good thing
Purchased new in April so have full warranty
Should I bring it up to service dept?....will they do anything if truck is running fine?
Thanks
I wouldn't worry if you don't have any engine noise or other noise issues.
Sorry to hear this.  Do you have a pic of the piece of metal you can post?
Also, when you say it was sitting at bottom of pan, I'm assuming you mean it drained and fell out from pan through the drain bolt hole while you were draining oil...correct?
Yeah it was sitting in bottom of tub I used to drain oil.....actually bigger than I thought it was....its steel not aluminum
Edited by Dunn
  • Sad 1
Still say if the motor isn't making abnormal noises, don't worry. That piece could be from anything. You have a warranty.
It is unsettling for sure.  But as mentioned, you have a warranty.  Be sure to document date, mileage, etc and keep that piece of metal you found.  You could mention it to dealer, but I don't believe they will document your findings.  Not sure dealer would have even looked in drained oil for any metal findings.
BTW....are the drain plugs non magnetic? Did you find it by running a magnet in the drained oil tub?
NOTE:  I'll be changing my own oil for the first time (500 miles) in the next week or so....I'll keep any eye out for what's in the oil.
Edited by SoCal Angler
Nah just found it sitting at bottom of plastic tub....I kept the oil and piece of metal and have it documented....drain plug is just standard
It might have been something from the manufacturing process that found it way into the pan and it not related to your engine?
Edited by elcamino
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
