I realize this may be a dumb question but I'm gonna ask it anyway.  Is it safe to use an undercarriage attachment for a pressure washer under these trucks?  Not gonna blast away at 5,000psi. just want to give it a thorough rinse after being at the beach for a week. Curious about any risk to any of the sensors etc. in the DPF exhaust system. Or anywhere else for that matter.
Nope. I would recommend to let truck to cool down some before blasting it with cold water.
The vent for the rear differential opens in the area of the fuel filler neck. The vents for the transmission, transfer case, and front differential all are routed to high points but I don’t know where. It would be good to know where they are and not spray there.
Anyone who has driven down the freeway during torrential rain knows the undercarriage gets hammered for as many miles as you’re driving. Probably not gonna have an issue. People don’t let their car cool down before going through a car wash that sprays the underside of the vehicle.
I only wash my vehicles by hand for one because I enjoy it and two I’m way too cheap to spend 10 bucks on a car was. Especially here in the Midwest it’s dirty in a few days anyway.
Usually they keep the engine running while going thru car wash. Keeping things hot.
But then again, us in the midwest will have a at temp vehicle and blow thru a snow bank. That is extreme. So maybe I am over thinking letting the cat cool down before dowsing it with cold water.
No I get what you’re saying and it probably is best to let things cool. I mean I sometimes spray off the lawnmower after a really messy or dusty cut but I always let it sit before I do. Just cheap insurance
In the old school dayz, it was a known fact, if'n one was to take freshly installed glasspacks and hot rod for a few miles to where they were cooking, stop and shove a garden hose in the end quickly, you'd "break" them in quicker! 😇
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
