madweazl Posted November 15, 2023 Posted November 15, 2023 Our remote start seems to work less frequently as time goes by. It works approx 65% of the time now and the condition is worse in cooler weather and/or sitting for a while (e.g. over night). Anyone else experiencing this?
GMCustomerService Posted November 15, 2023 Posted November 15, 2023 1 hour ago, madweazl said: Our remote start seems to work less frequently as time goes by. It works approx 65% of the time now and the condition is worse in cooler weather and/or sitting for a while (e.g. over night). Anyone else experiencing this? This is certainly not what we like to hear, madweazl. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2024 GMC Sierra 3500. To do so, please send an email to [email protected] with ATTN: madweazl/GM Trucks in the subject line. Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement. Privacy Statement | General Motors Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information. www.gm.com
newdude Posted November 15, 2023 Posted November 15, 2023 (edited) I have a 2022 1500 refresh so same fob and platform as your 2024 HD. I've chalked it up to either interference with some other device somehow, or, the vehicle just decides to have a mini stroke and something just doesn't let it do it. I've noticed if I lock, unlock and then re-lock the truck that the remote start will decide to work. However, it happened to my 2019 old body and my 2016 Colorado so I guess I'm just used to it. At work its the worst. If I'm inside the building it won't work unless I go near a garage door or man door and then it will send the signal for any of the functions. Edited November 15, 2023 by newdude
madweazl Posted November 16, 2023 Author Posted November 16, 2023 5 hours ago, newdude said: I have a 2022 1500 refresh so same fob and platform as your 2024 HD. I've chalked it up to either interference with some other device somehow, or, the vehicle just decides to have a mini stroke and something just doesn't let it do it. I've noticed if I lock, unlock and then re-lock the truck that the remote start will decide to work. However, it happened to my 2019 old body and my 2016 Colorado so I guess I'm just used to it. At work its the worst. If I'm inside the building it won't work unless I go near a garage door or man door and then it will send the signal for any of the functions. The lights will flash showing that it receive some command but not start. I'll try the lock, unlock, and re-lock but I've done similar with no luck (not sure in that order or not lol).
Another JR Posted November 16, 2023 Posted November 16, 2023 Sounds like it’s receiving the signal but is not starting because some control logic is preventing it. You may have already reviewed your manual, but the 2021 manual says: The vehicle cannot be remote started if: . The RKE transmitter is inside the vehicle or if the key is in the ignition. . The hood is not closed. . There is an emission control system malfunction and the lamp is on. . The ignition is in any mode other than off. . The hazard warning flashers are on. . Two remote starts or a remote start with an extension have been used. . The vehicle is not in P (Park). Maybe the system sets codes your or the dealer can read?
madweazl Posted November 21, 2023 Author Posted November 21, 2023 Wouldn't start a couple days ago so I tried the lock, unlock, yada yada a few times and it did eventually start. In my case, trying to start with the doors unlocked (failed) and then locking and trying to start again worked.
UWSkier Posted November 21, 2023 Posted November 21, 2023 What button sequence are you using for this? I've never had a remote start fail on my 2016 or my 2024 using the keyfob if I press Lock, Start, Start in about 2 seconds total.
madweazl Posted November 22, 2023 Author Posted November 22, 2023 On 11/21/2023 at 11:02 AM, UWSkier said: What button sequence are you using for this? I've never had a remote start fail on my 2016 or my 2024 using the keyfob if I press Lock, Start, Start in about 2 seconds total. From a locked position, 2 clicks on FOB works sometimes. The times it fails, the lights flash signaling it received a command but does nothing else. I've never not had it work on any other vehicle we've owned lol.
