My suspicion is this question has been asked and answered. Just can not find exactly what I am looking for.
Goal is to add a 12 volt plug to the bed of a 2018 Silverado. Trying to understand where the best location to bring power from. A couple years ago I added cargo lighting and connected to a plug beneath the bed by the spare tire. Wondering if one of the extra plugs would suffice. Would also prefer a plug that is not tied to accessory switch. In other words, hot at all times.
As a bonus, if I could get 110v plug back there as well I would go for it.
Thanks much for the help.
I am not an expert but have stayed at a Holiday inn, LOL! But IMHO, I think a lot depends on what you are wanting to use the 12v power for in the bed. And I'm assuming you are looking for full time power or did you want switched power? If it's something that wont pull a lot of amps, there should be several places to grab power from. A multimeter should be able to find the power source you need. Personally, I think I would rather have a dedicated feed and just run wiring up to the battery. I would use heavy duty wire and maybe a sealed 2 wire cable to do it. Amazon has many choices but maybe stick to a 10 or 12ga wire because of the length. Make sure to fuse it as well and maybe install a waterproof connector close to your 12v outlet in case it needs to be disconnected in the future.
As far as 110V, it can be done but you will need to install an inverter. Again, you will need to decide what you plan on powering with it. If you have the 110v dash outlet and were considering tapping into that, that's a mistake as that inverter is pretty anemic. A dedicated one as well as a higher output one is the way to go. And if your new 12v outlet circuit is "beefy" enough, many portable inverters will just plug right into one and then you have both.
Not looking to pull a ton of power. Mainly phone, GPS, and dog collar charging. And yes, full time power rather than switched. Knew there was a better term :) If 110v power requires another inverter then that is too much effort for this project.
Sounds like I have two options:
1) Tap into hot wire from somewhere beneath the truck.
2) Bring new wire from battery to back of truck.
Option 2 sounds more robust and would eliminate cutting of factory wires. I could also remove the bed plug and wiring in the future should the need arise. What else am I missing?
  • 2 months later...
If you just need power back in that area and not inside the bed, you can just purchase a 12V plug adaptor that plugs into seven-pin trailer power port. There is a main line in that port that is always hot.  If I recall correctly, it's the larger gauge red wire that goes to the center terminal and it's on a 30Aamp circuit.  If you need the power inside the bed, you can easily access the seven-pin wires under/behind the bumper and run a line up behind the DS taillamp.
Do your own research on which wire and terminal it is: it's been a while since I checked this out to plug in a macerator plug for my camper. I'm going from memory here.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
