GM removed the frame cross-member welded mount for the steering stabilizer on the HD's in '16. Going up my long stone driveway in my new '16 2500 HD, the steering wheel was jerking back and forth badly.  Looked under my friends 3500 HD, and saw the mount and a shock absorber to the cross link arm. I made a paper template off of his, and had my customer transfer that to a CAD drawing to cut one for me with his laser (for bolt hole accuracy), Mig welded it on. Added the shock, Worked great, shimmy and some road wander was gone.
In hopes my '24 2500 HD steering geometry was improved.........Nope. Going up the long crush stone driveway, wheel shakes like heck.
Found several mfg'g offer bolt on kits. Beware !!  I deal with metal fab for 43 years. Zoomed in on these brackets on line, some look very good. But the bolt through mounting on some to the cross-member, was very questionable. With those, I saw that there was no provision (thru tube in the cross-member) to add for that bolt) to stop pulling in the cross-member, when torquing it down.
At the lower control arm rear bolt where the other end of the bracket attaches to, only one mfg. had a key'd washer, to spread the load, when re-torquing that bolt back down.
I called that mfg. to also ask why he does not offer a gas filled shocks like others do. He explained, these gas shocks exert substantial pressure in one direction to the right, on the cross arm.
Makes highway driving a PITA. I asked if ANY gas shock mfg. offers a special "neutral bias gas" version IF that is design possible ?
Said no, it's a std off the shelf gas shock, just the proper length to fit this application.
Found several posts on other sites, with GM owners complaining of this right side terrible pull.
This mfg. explained, he Does offer Gas shocks , like for Dodge, Ford and others, where Dual gas shocks can be mounted in opposing force directions, to keep the steering Neutral. Said in GM truck applications, the conventional high quality shock works just fine.
I should explain what drew be to this mfg. to answer some questions.  Reasons: 4.
1) Some vendors sell his bracket, but offer it with a gas shock or conventional.  His site, only offers a conventional non-gas shock.
2) This product bracket includes a "Key'd" washer, to mount the bracket on the lower control arm bolt. This properly spreads the force on the cross-member 100%.
    Other suppliers that copied his basic design do not. Added cost ? Yes. Maybe a buck or two. To spread that load 100% around that bracket & bolt, is just a good
    engineering and safety practice, in a high load / stress area. Kudos.
3) To include a Through Cross-member Sleeve, to also spread the load  evenly to both sides of the cross-member, when other suppliers do not.
4) With all the well thought out mounting features of this product, again, why he is so against a gas filled shock in this application, when so many of us love gas shocks, in
     conventional use applications. A more expensive shock in this application, goes the wrong way !
This topic may seen trivial, but needed to be addressed in depth, once I got into it, finding out the little details.
I attached the PDF install manual FYI.
Happy Holidays to All !
SUSPENSION MAXX_SMX-SSB2520_GM 2500 KIT.pdf
Suspension Maxx, there I said it...
I was looking in to this too recently and came to the same conclusion as you did.
I hadn't decided on the shock to use for the stabilizer because I want it to match my other shocks... Bilstein.
Owner of Suspension Maxx, advised against ANY gas filled shock, in a GM single steer application, due to Bias Pressure in one direction. In this case, will always force the steering track to the right, constantly.
Ram & Ford that have dual steering shocks, using opposing pressure gas shocks is OK, to balance the force.
Installed mine, and found it not only stops steering wheel shimmy on my gravel driveway, on bridge expansion joints, manhole covers etc., no wheel jerk.
Also adds a nice stiffness to the road feel, in the steering wheel.
I had a gift card this Christmas for Rough Country and I did their Steering Stabilizer (V2). Like the Suspension Maxx design RC has the conventional shock, cross member sleeve and keyed washer on the control arm. With that said, I'll still give a nod to the Maxx as the better overall design imho...again I had 'free' money to burn. I did the stabilizer primarily for my wheel/tire upgrade I plan on doing at some point this year. I can say it's definitely a better ride than before, with the steering wheel holding more firmly to the road vs. feeling every pothole/uneven pavement section. It's an easy upgrade no matter what brand you do end up going with.
Anyone running something other than a Rancho with it? I ditched my stock Ranchos in the trash and a single one in the front for steering would bother my OCD.
Nice thing about it is you can't see it, 'cept for when a person drops the skid plate to grease.
You could rattle can it black. My ocd it's that bad yet and all my switch and receptacle plate screws are all vertical in the house and shop!
Just find an equivalent non-gas shock...In a few Off-Road specialty sites.  Someone posted a brand I can't recall. Even contact Suspension Maxx, ask for a suggested non-gas, non-Rancho, that will work with the kit they have.
My '24 HD Denali came with Rancho's, soon to be Bilstein's. I ran those on my '16 HD and loved them.
Tried a GM damper from a 2010 model a year before they discontinued it's use. Too short. Minimum collapsed length needed 14.25" & minimum extended length needed is 22" from my measurements.
Edited by Epsilon Plus
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
