I have a 2014 silverado with a 5.3 and 140,000 miles. I can't see a leak anywhere but I have a persistent and intense smell of gas in the cab and around the truck. Also when starting the truck it takes a good 25-30 seconds of cranking before it fires. Not sure if that related or not. I appreciate any help recieved.
The high pressure fuel pump is a known issue on those trucks. Intake manifold has to come off to replace also must replace two- one time use fuel pipes.They will have yellow stickers on them.The sound deadening cushion is probably saturated with fuel and should be replaced also.
It's one single-use pipe that's required. There is a second line that's recommended to replace, but not actually required.
3 hours ago, Zach Green said:
So that's what I'm trying to narrow down. Is there a way to test if it's leaking before I remove intake manifold.
Put an OBD reader on it and see if you have any pending or stored codes. If the O2 sensors are showing "rich" condition combined with LTFT showing significant reductions (double digits) under driving load, you could have a leaking HPFP. Another thing you can do is either pull the dipstick and smell for gasoline or change the oil and do the same.
If it's the HPFP, you're getting fuel leaking through the pump and directly into the engine. The fuel will contaminate the oil, reduce lubrication, and trick the O2 sensors into thinking you're running rich. If that's all happening, you'll actually be running lean AND have reduced lubrication of the moving parts in the engine so getting that pump changed as quickly as possible will be in your engine's best interest.
The long crank times are a clue. The pump is leaking externally and going , down the side of the bell housing . The smell of raw fuel in the cabin is a giveaway.  Put your scanner in live data mode and watch the desired  fuel rail pressure and actual fuel rail pressures. Turn the engine off and see how fast the rail pressure drops off. It should stay close to running pressure for quite a while. If it doesnt you better take the intake off and examine the pump before you have a fire.
The HPFP would leak fuel into the engine and it would be something that could be smelled in the oil. If gas is leaking outside of the engine, I believe the injectors or the fuel rail itself would be the more likely culprit.
I dont know where you are getting your information from. You can think what ever you want. I am trying to offer some advice to the original poster. I have been a line mechanic at a GMC Buick dealer since 1978 and may have slightly more experience then you do in these trucks.The high pressure pump can and does leak externally and also internally. The original poster already said no fuel in the oil so what does that tell you.Not a big deal to remove the intake and investigate before he has a fire and doesnt have to worry about a fuel smell.
I concur, removing the intake is fairly easy, leaning over the engine close to the sound absorption foam under the intake might revile the gas smell. And if the foam is saturated, then either the HP pump or lines are the culprit!
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
