Since the introduction of the ZR2 HD, many of us have waited for the parts to start hitting the market. They are now rolling out so let's build a thread where we can compile all the info on part numbers and related notes about converting a Z85 (standard) or Z71/X31 suspension over to the 1.5" lifted ZR2/AT4X.
First some press release links to the uninitiated:
ZR2/Bison - AT4X/AEV Edition
Long story short, the ZR2/AT4X has a factory 1.5" lift, extra underbody protection, and special dampers. The 1.5" lift is desirable because of the way it goes about gaining the extra height. Unlike aftermarket systems that use different torsion keys or attempt to ease up on the ball joint angle with a different upper control arm; GM uses a new upper control arm, lower control arm, steering knuckle and differential drop strategy. This allows for the 1.5" lift to maintain proper factory spec ball joint and CV axle angles without compromising ride or capability.
A few notes:
-So far it seems these parts will work on both gas (L8T) and diesel (L5P) powered HDs. At this time only the Multimatic DSSV shocks have unique gas/diesel/Bison/AEV Edition specs.
-The pricey Multimatic DSSV shocks are not required to run this 1.5" factory lift. Only proper shock height of an aftermarket shock will be required. For example the popular Bilstein B8 5100 is advertised for vehicles with 0-2" of lift.
-If you are looking for more of a leveled look, skip the rear lift blocks and leave the back of your truck stock. Going up 1.5" in the front should level out most factory HDs from a visual perspective.
-So far the complete part change list is UCAs, LCAs, Knuckles, Diff Drop Brackets, and Shocks for the front. Lift blocks, U-bolts (same as 3500 HD), Jounce Bumper Extension and Shocks for the rear. A one piece Front Skid Plate, Underbody Skid Plate (need confirmation on placement) and Transfer Case Skid Plate round it out. Bison/AEV Edition include unique part number Shocks and unique stamped steel Skid Plates (that at this time are extremely expensive).
-RPO for ZR2 is ZRX
-RPO for Bison is ULV
Part numbers:
Front:
Upper Control Arms:
Driver : 85144988
Passenger: 85144989
Lower Control Arms:
Driver: 85144990
Passenger: 85144991
Steering Knuckles (CURRENTLY ON NATIONAL BACKORDER AND UNABLE TO PURCHASE):
Driver: 85144996
Passenger: 85144997
Differential Bracket:
Driver: 86787383
Passenger: 86787384
Mutltimatic DSSV Shocks (non-Bison/AEV Edition):
Front Driver: 86557795 (Unknown if Gas or Diesel only)
Front Passenger: 86557796 (Unknown if Gas or Diesel only)
Bison: Unknown
Rear:
Lift Block x 2: 87844916
U-Bolt (same as 3500HD) x 2: 11610959
Jounce Bumper Extension x 2: 85565250
Gas x2: 86557751
Diesel x 2: 86557750
ZR2 Skid Plates (need confirmation whether AT4X is the same):
*Possible Front Skid Awaiting Confirmation* Underbody (need more placement details on where this is on truck): 85637479
Transfer Case: 85569359 (may need additional holes drilled in aft crossmember. Need more details)
Bison Skid Plates (need confirmation whether AEV Edition is the same):
Steering Rack: 85550010
Underbody (need more placement details on where this is on truck): 85550011
Transfer Case Skid Plate: 86513097
More info to come as it becomes available. Thanks to those on this forum that have done a lot of the leg work on this already @Joe97281 & @newdude
Edited by Epsilon Plus
Information adding/correcting.
  • Thanks 2
Thank you for this post!! I'm trying to determine if the DSSV shocks 86557795/86557750 will work on my 2020 Denali 2500 with stock suspension. Would a leveling kit with UCAs work? I don't want any more lift than necessary.
I just got off the phone with a dealer and they show the rear shocks as not available so I'm hoping they just haven't landed yet.
Appreciate whatever guidance you can provide!
Any info on the electronic locking rear diff components and compatibility? That would be a mod I’d be interested in doing.
  • 3 months later...
Came across this post as I dig into going with the AT4X lift on my Denali Ultimate.
Assuming this has been done successfully? Any update would be awesome
-Rob
I wish I could edit the original post as planned, but apparently that option times out. That said, here is some relative follow-up information from the larger discovery thread. This thread can serve as more of an up to date quick reference without digging through the minutia.
- This conversion works on both gas and diesel and has been successfully completed using all factory 2024 ZR2 parts on 20-23 trucks. GMC owners should substitute verbiage where necessary. X31 = Z71 and AT4X = ZR2 and AEV Edition = Bison. The swap mules on this site were Silverado but all of this will work with Sierra.
- At this time DSSV front shock usage will require modifying the hard and possibly soft brake lines on 20-23 trucks to accommodate the very large shock bodies of the DSSV. 2024+ non-ZR2s may not have this issue but no confirmations at this time. The preferred shock usage with this conversion is Bilstein B8 5100s as the standard versions of them allow for stock to 2" extra lift and are a perfect size fit for this 1.5" factory lift. Alternative to DSSVs if you want something in that quality/performance range try King remote reservoir shocks. At least they are rebuildable compared to DSSV and are of similar price range and arguably superior quality.
-85637479 is the confirmed front one piece ZR2 skid plate that replaces the plastic steering guard of all 4x4 trucks and the metal front diff skid of Z71 trucks. No extra bolts are required unless going from a non-Z71. The skid plate will be necessary to purchase when doing the full conversion as it allows room for the 1.5" differential drop. The stock Z71 skid will hit the diff if re-used. Non-Z71 trucks will have the bolt holes drilled and tapped already there waiting for the skid.
-The ZR2 transfer case skid is a partial direct fit. It will use (2) of the (3) bolts of the Z71 shield. If you are going from a regular 4x4 (non-Z71), you will need (2) 11518341 bolts (M10X1.5X25). The crossmember for the front skid holes will be drilled and tapped waiting for the skid. The rear of the skid will line up with the rear crossmember but you will need to drill and tap for (2) more of the same bolts, or alternatively like I did, drill through and use a through-bolt/nut/washer combo. I used a 3/8 stainless bolt with double washer and a lock nut. 2024+s may have the rear crossmember drilled/tapped for the ZR2 skid but need confirmation.
-The only item not reused on the swap is (1) of the (2) small 10mm bolts that help hold the brake hose bracket on the knuckle for each side. This sounds critical but the bracket holds on to the knuckle just fine in the stock divots and using the singular 10mm bolt. You can ziptie or figure out a way to secure the un-used top hole but the ZR2 knuckle is not drilled and tapped for it's usage in that spot. Use Loctite blue (low strength for future removal)  on the singular 10mm bolt if worried.
-There is two un-used bolt holes drilled and tapped on the UCA. These are for the routing of the 2024 brake lines that allow room for the DSSV. If you are converting a 2024+ over to ZR2 suspension, you may end up using these with your stock stuff and the above brake bracket bolt usage bullet point may not apply.
-ZR2s run LT305/70R18 (34.8x12R18) stock. Numerous ZR2 owners have converted over to 37s without trouble. This will largely depend on your wheel offset. I'm using a GM 18x8 with admittedly unknown offset, I am running Nitto 37x12.5s (36.5 actual height) with very limited rub on the front wheel liner. I've trimmed a small lower section of the liner and no longer have rub there. I have a touch of rub on the sway or frame at full articulation and turn lock but nothing audible, dangerous, or impactful long term. Those with custom wheel offsets that push the wheel out a touch should have no issues. Right now I'm sitting at 43 5/8" from ground to bottom of upper fender lip and about 44.5 in the rear using the full front/rear swap. I have not dialed it in all the way yet with the keys...etc until after I add the steering stabilizer (good idea when using 37s).
-Someone asked about using the e-Locker. This is likely a cost ineffective or impossible swap considering it is most likely tied into the BCM, ECM, and various other 4x4 modules. Just be happy with the good 'ol G80 that comes standard on all HDs. As far as fitting a unit in and somehow actuating it with something like a factory Aux switch? Well....get to experimenting.
I'll try to add more info as I learn it.
Relevant torque specs:
Front Lower Control Arm Ball Stud Nut: First Pass 37 lb ft, Final Pass 90 -100 degrees
Front Lower Control Arm Nut [2x] First Pass 133 lb ft, Final Pass 45 -75 degrees
Front Lower Control Arm Bolt [2x] is torque to yield (single use) part number:  11549229
Front Shock Absorber Nut (top) [2x]: 48 lb ft
Front Shock Absorber Bolt: 118 lb ft
Front Stabilizer Shaft Bolt [4x]: 37 lb ft
Front Stabilizer Shaft Link (end links) Nut [2x]: 74 lb ft
Torsion Bar Support Bolt [2x]: 92 lb ft
Front Upper Control Arm Nut [2x]: 192 lb ft
Front Upper Control Arm Ball Stud Nut:  First Pass: 37 lb ft, Final Pass: 90–110 degrees
Front Wheel Hub Bolt [4x]: 133 lb ft
Front Wheel Hub Extension Nut [8x] 96 lb ft
Front Wheel Drive Shaft Nut:
First Pass: 244 lb ft, Second Pass: Loosen 45 degrees, Final Pass: 199 lb ft
Front Wheel Drive Shaft Nut is torque to yield (single use) part number: 11612295
Front Differential Carrier Bolt (Go from the top down on driver side): 81 lb ft
Front Differential Carrier Bracket Bolt [4x] (bolts that go from the bottom up on both sides through the large bracket openings): 118 lb ft
Front Differential Carrier Bracket Nut [2x] (bottom up, pass side): 74 lb ft
Front Differential Carrier Bolt[2x] (smaller bolts, bottom up driver side): 81 lb ft
Rear Spring Unit Bolt Nut[4x]: First Pass: 74 lb ft, Second Pass: Loosen 270degrees, Third Pass: 74 lb ft, Final Pass: 175 - 185degrees
Rear Shock Absorber Bolt -Upper: 70 lb ft
Rear Shock Absorber Bolt -Lower: 118 lb ft
Wow, lots of great info!
Checked a bit more into this and didn't find any issues with running a factory 20-22" wheel with this conversion.
Ordered most parts today including the skid plate.
Current plate sits right up against the diff so needs more space, just as you mentioned.
Front sits right at 41" w/35x12.50-on stock 20's which are actually 34.5" and keys are cranked up a good ways at this point.
Any indication of what dealers make of this conversion when it comes time for warranty work?
-Rob
Wheel diameter won't be an issue, it will depend on tire width and wheel offset. Stock GM stuff should work fine and may only need minor fender liner trim.
This is the small amount I cut to alleviate the light rub on mine.
As far as dealer warranty it will depend on the service tech and whether they even notice. All the parts are GM stamped and painted black. No fancy looking aftermarket stuff....etc. On 35s they may just think you cranked the keys. If they were to measure or dig into the PNs they would figure it out or a very trained eye could tell a 24 ZR2 UCA from a 20-23 from the unused top holes for the brakes but most techs are just regular mechanics and not GM shade tree super fans like me. Officially, they have grounds to void steering and suspension warranty because of the numerous changes from stock. I'd rather not have Joey Bagadonuts service tech touching my truck anyway, so it matters not for me but for those concerned with warranty, default to a denial in your mind when modifying to this extent.
~1,600 for all suspension parts & skids. Figure ~$2,000 if doing it yourself (no paid labor) from stock to finished with a set of Bilstein 5100s.
  • 3 months later...
So I have ordered all the parts above however after speaking with my  mechanic he  swears that the at4x has longer cv axles than stock 2500hd and it’s not just due to geometry  . Can anyone confirm that the differential brackets change the geometry enough to account for this or do I indeed need longer cv axles .  For context he said he had a customer who actually lowered his at4x rather than lift it and they needed shorter cv axles .
-Rob
Was the differential brackets enough to change the geometry without needing longer cv axles? My mechanic swears that he had a customer who actually lowered his at4x and they had to order shorter cv axles to accommodate the drop. However I did ask him about the brackets and he had no knowledge of the brackets .
I highly doubt there is any change in axles. The differential carrier bracket difference (diff drop) is to correct the angle of the CV. newdude would know for sure but he's already investigated all the part number differences. The only thing that's still kinda up in the air about the full swap is the DSSVs on 24s. There was a hard brake line change that a forum member was dealing with but it never really got resolved. All that is confirmed is that the DSSVs won't fit 20-23 trucks without changing a hard brake line to accommodate the massive size of the shock body. Still unknown if ALL 2024s got the hard line change and can convert to DSSV or not.
Thanks for the response . I kind of figur s he was mistaken. And they didn’t know about the differential brackets being different on the at4x/zr2 so they changed the axles rather than the brackets . I don’t know why but it’s a new trend around here to lower full size trucks  like the 90s
Is there any info or pics of the main differences are between the stock and ZR2 components like ball joint angles/ positions, tie rod knuckle mount height difference etc.
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
