HawaiianRR: Brilliant!
OK, you may have convinced me to do this job. At least I may pull out the lifter(s) and inspect.
Just now, Bentley said:
HawaiianRR: Can you tell me how you inspected your cam?
I’m definitely not a mechanic, but I have lots of the necessary tools to work on cars. Follow some yt videos and you’ll be fine.
I took out the lifters and you can see into the hole where the lifters are and I used a scope camera to get a better look if there was scoring. Plus the broken lifter I took out, that roller was not damaged.
HawaiianRR: I think you've convinced me not to swap motors right away. Keep me updated on how it goes. Thx.
For sure. I’d definitely check to see how your lifter and camshaft is first.
Today I ordered about $600 worth of GM OEM parts to go back in.  Hopefully it all works as it should, if so, I’ll be happy with less than a grand to get this thing back on the road. If it happens again, maybe ill considered parting this ****** out or go try and cross a deep creek lol
  • 7 months later...
Anyone have these issues and found a solution?
Our 2017 6.2 Sierra started something similar last winter, mainly when it was below freezing and wet (going thru a carwash in the winter). Check engine light comes on and will flash, traction control will come one and engine will run rough. Code reader shows a misfire. I believe it was cylinder 8 last winter.
Fast forward to this winter and it's back. This time cylinder 5 misfire. This happened to us on Christmas eve when driving home (12 hour trip). Given the situation we had not choice and decided to continue driving thru it. For about 4 hours (until the roads dried up) the check engine light was on and would occasionally flash. When this started the traction control light was also on. However the Traction Control light would come and go. Every time the Traction Control light came on the oil pressure would rise (10 PSI or so) and as soon as the traction control light would go off, the oil pressure would drop back to normal. This was a clear repeatable pattern.
I have had a few people look at the truck including the local GMC dealership and they can't recreate the issue. Also they tell me no codes are saved that are any help.
I feel the issue is something electrical as it's triggered by low temperatures and moisture. The traction control light and oil pressure increase has me stumped.
I should note that the truck returns to normal once the Check Engine light goes off. We have put probably 15K on it since the issue first started last winter.
Edited by stoltz423
Sounds like bad wiring at the front of the engine.  Oil pump solenoid harness or the jumper harness it plugs into.
Mileage/kms ??
You are describing my (old) engine exactly.
On a scan, the oil pressure spikes BEFORE the misfire. This seems to indicate non-electrical, that is a mechanical defect.
You can read my thread for details, but I replaced many parts - including oil pump - as I thought it might be the relief valve in the pump being faulty.
In the end, it was a bad lifter, which ruined the cam, and quite possibly hurt the valve.
Considering the high mileage on my truck, I just received my new engine. For me, the rebuild option did not make sense.
Lots of info on low oil pressure but not on high oil pressure.
My theory: The bad lifter is causing the computer to increase oil, or at least leak oil. This influx of oil works on the back end of the pump to offset the relief valve, thus causing high oil pressure. Just a theory, not looking for arguments.
12 minutes ago, Bentley said:
Mileage/kms ??
170K today but when it started last winter it was around 155K. Maybe my thinking is wrong but if there was something internal wrong with the engine, lifter, cam, etc. would it have gone all year and 15K without issues? Seems to only happen when it's below freezing and there is a lot of moisture in the air.
I was a little fooled at first with weather temp.. In my case the lifter 'bearing' was shot. Like any bearing, I am sure that the fail is sporatic at first until it fails completely. Maybe in cold weather it contracts  - Idk?
If the cam is still good, you are fortunate. FYI - if you replace lifters, do all of them, and replace the VLOM.
Good to know.
Are you saying yours was weather/temperature dependent also?
Also did your Traction Control and CEL lights come and go or once it started the lights stayed on till you got your new engine?
Just got my engine, not installed yet.
Read through this post from beginning. It may answer some of your questions.
are you still driving the truck or is it inoperable at this point?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
