newdude: Well that gets rid of one possibility.
Can't figure it out. I start the truck and about 15 seconds later I hear a click and the oil pressure spikes.
Now, after the spike, I hear a buzzing in the engine.
About ready to look for a cliff.
newdude (or anyone):
So there must be a relief valve for the LT engine, am I correct.
Where is it located if not in the oil pan? or how does the system deal with excess oil pressure?
  • 2 months later...
2015 5.3. mine is giving me same symptoms but I doesn't just do it at startup. Sometimes it's fine on a 100 mile drive then will start missing traction control popps on and oil pressure goes from 40 to 55pai. I will keep driving and in a while it all goes back to normal like you say, like a switch
Davis84: My scanner shows this order of events:
1) everything normal at startup
2) oil pump high pressure solenoid shuts (off I think) - this creates the high pressure
3) misfire immediately after
Apparently there is a pressure relief valve in the oil pump. (LT engines) So I am just about finished: new oil pump, new vvt solenoid, fixed oil pan leak etc. New motor mount. The job was massive (for me).
I will have it running (hopefully) by next week. I am guessing that the pressure relief valve was stuck closed. So when the 2 stage pump kicks into high pressure mode, then the relief valve does no do its job.
PS: check something out on your truck. The pump kicks in to high pressure at around 3500 rpm. See if that is when your oil pressure spikes.
I will do. But I was running at hiway speed under 2000 rpms when it last occurred. I think it is an ecm problem. Man please let me know how yours works out. Good luck
Not yet. Put new wires on mine and had a frayed wire on #8. 166600 miles, now instead of a #8 misfire gotta random misfire, gonna put new plugs in this week. I won't remember to post the outcome so if you would. Make a post to this thread and I will let you know how it works out.
Kbrock3397: Well, problem not solved. This is what I have done so far:
- Walnut blast to intake
- new VLOM
- new plugs, wires, injectors
------------ First project no change
Then:
(I had an oil leak so some of this I had to do anyway)
- re/re oil pan
- new oil pump (thought that the relief valve might be stuck)
- new VVT solenoid
- new wires / and some sensors
------------------ Second project (massive) no change
I am bringing it in to GM this week to get diagnosis.
Engine does not tick or sound funny, just the same misfire AFTER spike in oil pressure.
I have researched this up my ying yang. Lots of problems with low oil pressure, but nothing related to my issue.
We will see what GM says - unless someone has a better idea...
Dang I hate that, right now I have already replaced my spark plug wires and a coil on number eight and Monday we are going to replace all the spark plugs. I will let you know how it turns out
asilverblazer: Possibly, but the main culprit is the spike in oil. The misfire is secondary to that (according to my scanner)
Wonder what level of scan tool would be able to take over control of (or at least monitor) the oil pump solenoid... turn it off and see if the miss fire clears up.
The only way oil pressure could affect engine performance would be through the DFM lifters.
Maybe the oil pump and pressure are as intended (no codes) and the lifter is the problem.
In other words, so what if the oil pressure spikes - none of the other cylinders have a problem with it.
Edited by asilverblazer
asilverblazer: I kind of agree, except that the pressure spike is far above spec. The spike in oil pressure triggers the engine light. The misfire triggers the engine light 'flashing'.
As well, after warming up, the oil pressure is higher than normal.
All of that said, the truck has 260k (km) and it would not surprise me that the lifters are weak.
PS: I think my scan tool can turn the solenoid off, but I am not competent enough with it yet.
Edited by Bentley
Correction
I guess I missed where the oil pressure spike is setting the engine light. What code specific to that is there?
What is "higher than normal"?
asilverblazer: Yeah, so when cold there is a spike that happens about a minute after idle. This sets off the engine light blinking, and immediately causes misfire.
I will shut engine off and restart. Repeat above, until engine warms up. As the engine heats, the oil thins and the spike stays low enough to not trigger the engine light blinking.
After warmup, the pressure is about 1 - 2 o'clock at about 2500 rpm (275 kpa is 12 o'clock which I think is normal)
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
