This is a fun one. Truck runs at normal temp until I try to pass of highway at 80 to 100 mph. Then the temp skyrockets to 260, shut off the ignition and coast for about 3 minutes. Turn on the truck temp drops to normal and runs at 80 for hours with zero temp fluctuations. New thermostat, fluid. No issues at low speed or in traffic. Hose collapsing?
Did you install an OEM or aftermarket thermostat? And why did you change original thermostat?
Edited by mikeyk101
Had that happen to one of my suburbans,
the front of the radiatior was covered with bugs after driving through a swarm of them.
And coasting with the engine off sounds dangerous.
Edited by Earl Cordova
Happened to a friend. He took his truck to the shop for the mounting of new tires from 4Wheelonline and new radiator with an aftermarket thermostat. He ordered a new set of oem thermostat and never overheats at 100mph.
17 minutes ago, asilverblazer said:
Curious why the t-stat change would cure it.
I know on mine, when my thermostat went bad, I put in a Motorad one that was a 194⁰. It worked fine at first but after several months, it began to fail and wasnt opening when it should. I'm guessing it was stuck closed. With the thermostat stuck closed, the coolant never circulated through the radiator so this caused the higher coolant temperatures. Not only did it stop opening at around it's rated 194⁰, but also wasn't opening at the OEM 207⁰. I replaced it with a AC Delco 194⁰ and it has worked fine ever since.
Sure, but in the cases above only at high speeds? Plenty of airflow through the radiator, that should lessen the effects of a poorly operating t-stat. (If the t-stat isn't opening, why symptoms only at high speed? It should have symptoms at other times too where engine load is high.)
I don't know but that the exact symptoms as I experienced. If a thermostat is stuck closed, it won't allow coolant to flow into the radiator so no additional cooling. I was able to check mine by grabbing the upper hose from thermostat to radiator while motor running and could tell that hose wasn't heating up so no flow. I verified coolant temps by using an OBDII reader and not by going off the highly inaccurate dash gauge. Dash gauge will read steady 210⁰ whether the coolant is at 185⁰ or up to 225⁰. I do know at under load (higher speeds), obviously more heat is generated by the motor.
Just to add, under idle or mild local driving, I didn't see dash gauge move at all but once I got on the accelerator and got up to highway speeds, I would see the dash gauge rise so I knew that it was in excess of 225⁰.
Huh, I guess that's it then. I would expect overheating symptoms (high gauge reading) of a stuck t-stat to exhibit more often than just on the highway above x mph.
Make me think that maybe the aluminum block can dissipate its own heat effectively enough... given that generally speaking there aren't many fundamental differences to significantly alter the cooling system performance.
I'm not arguing, just discussing the seemingly odd/specific/isolated symptoms of a stuck t-stat.
I'm guessing with the stuck closed thermostat, it was still running hotter than normal at idle and local driving but wasn't apparant by just watching the dash gauge. As I mentioned, the dash gauge goes right to 210⁰ whether the coolant temp is 185⁰ or as hot as 225⁰. It's also possible that my Motorad thermostat might have been only partially opening and not allowing full flow above 194⁰ as it was supposedly designed for. And as a result, when running at higher rpms and harder throttle situations, the problem showed up.
I first noticed the issue while traveling down the highway when my dash gauge rose just a bit every now and then which wasn't normal. On checking using the OBDII reader instead, I saw that coolant would occasionally get up to 230⁰ while rolling down highway but then drop down to 215-220⁰ after slowing down. Sometimes a little lower but not by much. Once I saw that, I looked further into it. That's when I discovered while investigating in my driveway that the coolant was not heating up in the upper radiator hose from t-stat to radiator. Once I changed to a GM brand thermostat, (although it was a 194⁰ one for 6.2l Camaro, Corvette, and Caddy CTS motors), coolant temps would stay in the 190⁰ +/- a few degrees.
I originally went with the colder Motorad t-stat and then changed to the GM one because on occasion I tow a toyhauler. I wanted to get coolant flowing through the radiator sooner to help with keeping overall coolant temps lower.
Interesting you bring this up. I did notice that when I had the coolant issue, my oil temperature was also affected. Normally oil temps run very similar to the coolant temps. When the coolant temps were running in the upper 220⁰ range, the oil temp was also in the 225-230⁰ range. It never ran that hot before except when hauling the toy hauler up grades. After changing the coolant t-stat back to a GM, as coolant temp stayed in the 190⁰ range, so did the oil temperature as well.
Another thing that came up was the transmission temperature. I had changed over to the updated 154⁰ t-stat some time ago. When normally running down highway, it will stay in the upper 140⁰. In stop and go traffic, it does sometimes rise to upper 160⁰ range or even slightly higher in occasion but then drop back down once rolling again. When coolant problem showed up, the transmission temp started regularly running in the 160-170⁰ range and even went up to upper 180⁰ a couple times. Once the defective Motorad was replaced, transmission temp dropped back down to where it was supposed to be again.
Makes sense, since the t-stat opening and closing is the primary means of regulating the engine temperature, all other temperature readings would track with the performance of it.
The temperature of the engine determines the oil temp, and a hotter engine can also transfer additional heat to the transmission.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
