2015 High Country 1/2 ton, 6.2l, 85,000 miles.  Noticed temp gauge reading consistently about 190 degs, my geriatric brain remembers it used to run around 210 degs.  So, I'm guessing I need to replace the thermostat?
Now the questions: What brand/part# would you suggest?
                                  Should I change the Sensor at the same time?  If so, brand/part# suggestions please.
Thanks for any help offered!
Just replace the thermostat, the temp sensor is fine.
If you can get an OEM thermostat, go that way but some places are hard to find them and they cost a lot.
Otherwise my suggestion is Napa, they have a good warranty on their part and it's what I've been running for years now.
OEM I think is still on backorder.  If you can find one, go for it otherwise like CamGTP mentioned Napa is a pretty good choice to go with.
CamGTP and newdude - Thank you for the fast response!  OEM is hard to find like you said, think I'll order a NAPA.
Just wanted to add that normal operating temps will have dash gauge at 210⁰. But... The actual temp even though gauge reads 210, will be anywhere from 185⁰ to 225⁰. That gauge is very inaccurate. If you are using the dash gauge to tell your coolant temperature, once it moves down from 210, it is already south of 185⁰. So you are probably actually in the 170-180⁰ range instead or lower.
Have the same issue. Actually started acting up after I upgraded the transmission thermostat so I thought it was normal.
Please let me know if i'm in the wrong for doing this but I have a OEM thermostat for the 5.3l. I had bought the OEM engine thermostat when I noticed it was slightly less than the 12 o'clock position and it was on backorder through amazon so I put an aftermarket one in my 2014 Silverado 1500 I had and then the OEM one finally came in the mail through amazon. Of course I sold the truck just after the parts came so I have some extra parts from it for maintenance. Let me know if you want an OEM one and I can sell you mine.
And you are right, if the temp sensor on the dash is not at the 12 oclock position then your thermostat is likely sticking open. My second t-stat on my 2014 was the upgraded GM thermostat and it somehow warped itself even though I never overheated ever but it caused the coolant to always flow and excessively cool itself. I changed the t-stat before it would eventually trigger a check engine light for running too cool.
Edited by kickass audio
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
