Just recently purchased 2024 Silverado LTZ - noticed the next day when coming to a stop, when we were talking inside, and possibly when accelerating that the volume of the radio decreased to a lower volume and then comeback after 15-30 seconds..
Has anyone else experienced this?
Assuming the speed sensitive volume isn't on, radio probably needs an update.  One of the more recent updates solved the sudden volume raise issue I think.  If you don't see one come through as an OTA update, it probably needs a trip to the dealer.
If the speed sensitive volume is on, go into the radio settings and you can change it.
Edited by newdude
On 2/18/2024 at 5:07 PM, Officemonkey said:
Unsure how to access the Speed Sensitive Control Menu.. Nothing in the settings menu that i could see..
Yeah, I don't see any speed sensitive volume on mine, and nothing is said about it in the manual, either. I'm actually kind of miffed about them doing away with that feature. It was awesome, and I miss it! They want you to not adjust a bunch of stuff while driving, yet you always have to change the volume as you speed up and slow down. Doesn't make sense ar all.
Edited by MrLeadFoot
8 hours ago, nichos said:
It should be in Settings->Apps-Audio->Auto Volume:
The 2023+ have a TOTALLY different Infotainment system and that setting is no longer there anywhere.
Did anyone ever find a solution to this? Ours is the same as the original poster. 2024 LTZ, my phone works fine, but the wife's phone the volume drops for 30 seconds. No notifications are coming in, no speed sensitive volume setting (that is only available in certain regions). Radio and iphone are up to date for software, checked with dealer and there are no other updates/service bulletins for this.
  • 6 months later...
I've taken by 2024 Z71 in 3 times and this Friday will be the 4th attempt to get the volume to not drop or cut out completely. They did give me a new radio, but the problem persists.   In the last month the tailgate has not dropped 3 times.  And the Apple Car Play froze once.   Love the truck, but these should be easy fixes and for some reason, Chevy can't get it right.
  • 4 months later...
i have a 2025 silverado 1500 and after a few second of driving the radio volume will significantly drop. Anyone know the possible cause of this? It’s only for my music btw, notifications will be ear bleeding loud when they pop up but after that the volume drops significantly again. the truck only has 125 miles🤦‍♂️
    • I wonder as well, why they would send me a text message with links to these suggested procedures totalling over $10,000 without even the slightest hint of how they arrived at these being necessary.
    • https://precisionlubrication.com/articles/oil-filter-efficiency/     For them it is a problem of $$$$ and compliance. To cover both they have to lie from the heart.    Government wants low waste oil numbers so the bar needs to be very low on contamination to met that requirement.  Consumer wants cheap maintenance (perceived cost). Again requiring a low bar.  OEM wants high margins at a cost effective warranty rate and lots of repeat customers. More low bar.  Filter manufacture wants the same thing the OEM wants. See the pattern?   Consumers are fickle and also want perfection requiring a HIGH bar. Inconsistent with all of the above. Consumers can be, when the put their minds to it, inquisitive, love winning arguments which requires some useful information to be available to support them. And this is where it gets sticky and the lies begin.    Information needs a solid well grounded point of reference if we are to compare in a useful way. There is a standard for this.  ISO 4548-12. This standard sets the particle size at a specific Beta ratio and darn few are faithful to its intent.    If they don't state the test method they change the particle size or the Beta ratio to hit a perceived favorable standard. They obscure the information in a way as to prevent direct comparisons leaving the consumer with one method. UOA's with an ISO 4406 test result. Pricey and not allot of labs willing to do the work. Lobby work happens everywhere, not just at the seat of government.
    • IF,IF,IF. If they cared about quality instead of profit and this applies to any company, what a concept.
    • Good Morning Gents..hope everyone is enjoying a beautiful saturday morning. I have a 2001 GMC Sierra that I bought used in 2018. I am the 2nd owner and its a beautiful truck. Ive put about 60,000 miles on it and recently the front end has felt funny. Kind of loose when hitting bumps adn sometimes I actually feel a "bang" in the steering wheel. I took it to a local guy who said that everything was tight and he tightened the steering box. It didnt feel much better, so I had him replace the front shocks, which had noto been done since I bought it. It had the check enging light on so I took it into a local garage to fix that and check out the suspension. Everything is original and the rubber bushings that I can see look bad. They said everything was tight and there wasnt any play in the front end. Im concerned about the banging feeling in the wheel. Ive been driving this truck for 8 years, so I know how it usually feels and this is something new. Its a second vehicle, so I dont drive it all the time, but Im trying to use it more often. I live out in the country and some of the  roads are kind of rough and I alive on gravel roads. Anyone deal with anything like this before?
    • Yes of course. There’s no experience in the Trump organization in hiring contractors. it’s not like they’re experienced in that field.😆
