i've seen where a shorted out starter hot wire blows it, the power wire feeding the starter rubbing on a heat shield or anything metallic can do it too. Also something with a bad jump start potentially can do it.
Welcome to the Forum! It would have to be a dead short pretty much. I agree with K A, check the battery cable to the starter
48 minutes ago, Sloan17 said:
I found the problem. The water pump is seized. High starting amps blew the fuse. Thanks for the reply’s.
dang I would never have guessed that. How did you not burn up the belt? My dad's 97 Tahoe had the A/C compressor seize up on him from constantly refilling due to a small leak and not putting any PAG oil in the system. When his compressor was stuck the drive belt melted and caught fire under the hood.
i agree Kick ,somethings not making sense, water pumps get looser, not tighter, the belt should have burned or broke, there's more to it I'm sure. I guess if it just popped the fuse he's lucky
I’m not exactly sure when the pump completely seized. I stopped for gas on the way home from the dealership and the truck wouldn’t start. After trying to jump start it, I called AAA and they towed it home. The next morning I pulled the starter out of the block with the wiring attached. The bendix worked, but motor didn’t. I decided the wrecker driver was right and bought a replacement at $ 359.00. Same result. Went online and researched what else it could be and found out about the buss on the battery being fused. Volt meter told which fuse was blown. A new buss was a dealer item, so I jumped it to ( with jumper cables)troubleshoot further. First time it started fine and ran for ten minutes at idle then died. Restarted with a eye to eye battery cable and smoke came from the front of the engine. Started troubleshooting the next morning ( thought I had burned something electrical with the jumper wire) and found nothing wrong electrical. Restarted the truck and could see (in the daylight) that the belt was slipping on the crank pulley. Found the water pump pulley too hot to touch. Pulled the belt off and found the pump seized. Engine never ran hot or leaked any water. I’m 63 years old and have never seen this type of failure before.
Let us know when you get the pump off if it was just the bearing or some other failure. Sounds like something might have got caught in the impeller
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
