Newbie to this forum searching for help.  I have a 2017 Silverado 1500 4x4 crew cab truck.  I have driven the truck 100,000 miles with very few issues.  One day at start up the airbag light was on in the dash and the message center.  I took it to a local mechanic.  He ran diagnostics and came back with an airbag sensor fault and a rear P/S seat belt issue.  I replaced the defective sensor under the core support.  He cleared the code and then the code came right back.  Can someone guide me in fixing this problem? What is the seatbelt issue?  It is my understanding that the airbags will not work if there is an error code.  Thanks
Do you live in the snow/Salt belt? You may have a bad/corroded wire or connector for both. Bad grounds are a known issue with out trucks. Search YouTube for ground fixes. Start with the simplest things first, if that doesn't correct it, go to the more expensive fixes next. You really need a guy like Eric at South Main Auto trouble shooting it rather than using the parts cannon.
What codes did you have before the sensor and what codes do you have now?
So here is the error code that my mechanic found B0085, which appears to be a left front side impact sensor.  I haven't found out where this sensor is located yet, but I will check it out tonight.  He says, according to his snap on scanner, that is the only airbag warning code there is.
No, the front impact sensor was bad.  I replaced it myself.  It was cracked and swollen out of proportion from water/salt damage.  At least it appeared to be, compared to the new one..
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
