59 minutes ago, s10dragracer888 said:
Hey guys, what’s the chance it’s improperly balanced driveshafts, like a previous poster said. Maybe the driveshafts themselves are the problem, and OEM isn’t the right answer?
I'm 90% sure it is the front axles.
  • Thanks 1
I have a 2024 wt and I don’t have the vibration. It’s 4x4, 5.3, 10-speed.
it does have other issues though.
It's entirely possible you're still dealing with a tire issue. I went through this a few years back with an F150. Smooth as glass on factory tires, then shook like you describe at 70 after getting them replaced with Goodyears. Balanced, re-balanced on the road force machine and still did it. Warrantied the set and those shook. Warrantied again and switched to Coopers and those shook again! Had those tires road-force balanced at another shop and that finally fixed it. It was implied the previous shop had a tire balancing machine that was out of calibration.
I had this issue with my 25' SLT. I took it in, and they rebalanced it. It seemed to go away, and I do have the range DFM disabler. I will monitor and report back if it returns.
Turns out that my issue was the bfg ko3 tires I had put on it. Thankfully the tire dealer replaced them with my choice of tire since I had reported the issue to them twice after the purchase back in May.
I spoke too soon, went on a short trip today and vibration is still there, around 1400 to 1500 rpms. Seems to only be noticeable after driving 10 miles or so, then it starts.
I've been back to the tire shop twice for balancing.  They even had a tech come out and calibrate their tire balancer.  Still had a vibration.  Took it in for the road force balancing, and the vibration comes and goes, but is still noticable.  Unfortunately, our roads here in the winter aren't very smooth now, so the vibration is usually overwhelmed by the rough roads.
  • 2 months later...
As someone who's done a lot of troubleshooting on this, including installing brand new OEM 20" wheels in place of the stock 22" wheels on my 22 refresh Denali, as well as have spoken to lemon law attorneys, I've noticed that I don't feel it when there's a strong cross wind. Could it be wind turbulence we're feeling? I ask this partly because it only happens at moderate to moderate-high freeway speed range , I don't feel it when in a strong cross wind, and I have never heard of someone with an AT4 or Trail Boss complaining about this.
Edited by MrLeadFoot
  • 9 months later...
Just wondering if anyone has had resolution of the vibration issue.  My 2024 2500 AT4 was vibrating on the way home from the Out of Town dealer.  Balancing, One new tire, Set of New tires,  Never really went away, Now at 52K Switched to Michelins from the Goodyears and new brakes all around.  Still have a vibration between 60 and 70 which is where it all started.  Any ideas would be appreciated.
Edited by Mike Renforth
missing info
There goes my theory that it might be a wind vibration, given you have the 2" lift, and I thought it might be wind going under the "normal" height models.
That said, I have noticed that if I put my fingers in the area between the door and body while driving, I can feel the slop between the two pieces as they move around inependently of each other. Not enough to let wind in, but I can't help but wonder if all the body parts have that much tolerance, could the vibration be from these parts shifting around? My son's and daughter's Hondas don't have this much play, and neither does my wife's Mazda CX5. I also don't recall my Suburban being like that either, and it didn't vibrate like this truck. It is entirely possible that all the trucks have a wider tolerance and thereby vibrate because they simply didn't make them as tight as their other vehicles. I've been trying to find someone with a Tundra that I can ride in and see how they are but I would venture to guess they are tight and smooth.
  • 3 months later...
Did anyone find a resolution to this problem? I have my 2023 Silverado 3.0 in the shop now for this problem. They have checked, driveshaft balance, cab and engine mounts, axle run out, torque converter lock up and pinion angles. I’m really starting to believe it has something to do with the ARC as most of the people I see commenting have that on their trucks. Like most I have dealt with the wheels and tire solution to not fix. My OEM wheels had the shake and 2 set of aftermarket wheels and 3 set of tires later I still have the shake. All my road force numbers are great. The dealership placed my wheels and tires on another truck with ARC and that truck would shake. I’m going to ask them now to place my wheels and tires on a truck without it and see if it shakes. They also placed the other trucks oem wheels on my truck and my shake is still there. Any help would be appreciated. GM field tech believes it’s my level kit but I know it is not that.
After changing tires, I ended up having a nasty vibration… But even before, I did notice a vibration at about 70 mph. What ultimately fixed it was a set of good quality tires, paired with a different set of rear shackles to raise the rear end… Ultimately changing the pinion angle. That may be where the problem lies with these trucks… Because I've noticed that a lot of of them don't have shims between the rear axle and the leaf springs.
  • 1 month later...
I have a 2015 2500 Denali with the same problem. Did anyone find the cause of the problem!
Also I had a 2003 Chevy 2500 2 wheel drive that did the same thing.
    RSTRICK
    RSTRICK
  • Who's Online   4 Members, 0 Anonymous, 642 Guests (See full list)
    • Guys that read Dizzy's thread know that eons ago after multiple manifold pulls to clear the CCV orifice I converted it to a PCV system with an orifice below it via the valve cover. The blow-by (sticky rings) was so bad it was impossible to keep clean and accumulated water in the oil in the winter when the moisture would freeze in the fresh air side. The PCV functioning mainly as a check valve. I carefully sized the orifice to reproduce the factory values for crankcase pressure at idle.    Well...took a slug of oil to get my attention but the ring seal improvement meant the system was over drafting sucking oil up and out the breather. (V8 guys with orifice systems are nodding their heads). So today I choked it down...allot....to replicate the "just enough to hold a piece of paper on the fresh air side at idle". May still be to much but I'm working with shims at the moment. When I get it sorted I'll make a proper plate and plug. Perhaps using carburetor jets to tune it.    So I guess this means it isn't my imagination.    Dizzy is a pig guys so don't go expecting huge moves in equipment (your equipment) that is in much better shape. A needle valve....lord that just came to me....
    • I had a new engine installed with under 5,000 miles. It shut off coming around a residential street corner and wouldn't restart. Dealer indicated it seized. New one has been fine since with 10,000 miles on the replaced engine. Annoying but I was given a loaner for the 5 weeks it was down. I won't go with the 6.2l gasser so it's 3.0l again. I love the economy and it tows my enclosed car trailer just fine.
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
