So I decided to put 2017 Escalade suede A and B pillars on my Sierra see if they would fit and they do
Also the black oh ****** handles off of an Escalade work as well. Going to see if the sunvisor fit as well later this month
Hey where did you get the parts? Online, scrap yard?
Any pics of the B pillar ???
Sorry for the late reply
Online GM Parts Center
22894407 - Jet Black Roof Rail Assist
23340560 - Jet Black Passenger Side Windshield Garnish
23369505 - Jet Black Driver Side Windshield Garnish
Sorry by B pillar I meant passenger side pillar
On 2/3/2025 at 11:13 AM, asilverblazer said:
Headliner?
Headliner did it myself
bought online from headlinermagic.net
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
