Quick question, and not sure if this is even the right sub section for it? But wanting to grab a scan-tool. Don’t need the most “pro-level” tool, but enough to read codes and get into the oem side menu to view various modules for codes. Also bonus points if it works on a Toyota car also (I have a chr I use as a work ride to save on gas and wear on the truck)
now I know it’s the new global b system on my new truck. So is there suggestions of a reasonable one? Doesn’t need to have a Bluetooth dongle either. There’s like 10 different ones and I have no clue to what’s a good one or a waste.
thanks guys
I have been considering a scan tool for my ‘23 6.6L gas with 6 speed and Toyota vehicles.  I believe bi directional scan tools are preferred to allow for more than just pulling codes.
The Car Care Nut over on YT has pretty good things to say about one that he reviews on his channel.  He discussed its uses on Toyotas, but it works on most vehicles. Vid is 3 years old and no updates on the tool.
Not sure if this even fits what you’re looking for but, I running the Scan Gauge III.
It will give you codes and the ability to clear same but its basic ability is to provide real time engine operation parameters. Maybe not what you are seeking. It’s hardwired and so far, has worked very well on my 2024.
Make sure what ever you're looking @ works on the current GM vehicles. I bought a Creader Launch Elite G. It only partially worked w/ my 2024. i bought the adapter that supposedly would correct this, it didn't.
I wanted to be able to adjust the TPMS thresholds, but am unable to w/ this tool. Apparently there are scan tools that do permit this.
I guess I can use it for any code reading...
Edited by revrnd
On 4/12/2025 at 10:13 AM, Chopper_Man said:
I use the Autel MK900-BT, does everything I need on all my vehicles.
Do you have anything newer than the 2022? According to others on here, GM changed the 'architecture' w/ the '23s or '24s. What worked on previous model years may not be compatible.
Edited by revrnd
I have been using a BlueDriver for several years.  It is very small which makes it convenient to keep in my center console, and move it from vehicle to vehicle for trips.  It interfaces with your smartphone via Bluetooth.  I have been getting a nuisance code on my 2013 C3500 for years, and while driving, I am able to plug in the BlueDriver, open the app on my phone, clear the code, unplug the BlueDriver, and toss it back in the center console.  I had a turbo code on my 2005 K3500 and went into limp mode while towing a trailer on a narrow canyon road.  I almost came to a stop with traffic behind me.  I was able to quickly plug the BlueDriver in, clear the code, exit limp mode, and resume my drive.  There was nothing wrong with the turbo, and it never came up again.  https://a.co/d/4IiAABx
I purchased the Autel TPMS Programming Tool TS508WF 2024 Version after reading advice on this forum.  I used it to reprogram my 2024 2500HD tire pressure threshold down to 50 psi because that is what I run my tires at, and the low tire pressure warnings were a pain every time I started the truck.  It worked great, and I have also been able to use it to relearn the tire locations after a rotation.  A little pricey, but the cheapest way to reprogram short of having a friend do it.
Thanks. I checked online & that sounds like what I should've bought in the 1st place. Any Canucks interested in what I posted previously, PM me...
I ordered the TS501. Not really sure what the difference is, but is priced cheaper than the TS508
I had bought my TS508WF from Napa and I got a little off of it so it was 325.00, then early this month Princess puts it on sale for 280.00 and actually that sale ends tomorrow as per April 20th. However with Princess you can either possibly get a raincheck if they don't have one in stock or if you have that sale catalogue you can typically walk in after the sale and point to the price in your catalogue and they will sell it for that price. The regular price at Princess is 400.00 so that was a crap price.
Good question about the 501 vs the 508, I am guessing that the 508WF would be the wifi difference but a regular 508 I have no idea.
I've never thought of looking for scan tools @ PA before. If I'm in Oshawa, I usually make a stop @ the 1 next door in Whitby.
You certainly didn't miss out on anything with their regular price, just a fluke they happened to have a sale on them just to piss me off LOL. Certainly not worth 20.00 for a special trip and find they don't have any as their tracking of what the store website says they have and what they actually have are pretty sad at times and part of that is there system and part of it is certain items that walk out under someone elses power.
Some of what Princess will have in the way of scan tools are there because they are out of date and on their way out, not made anymore etc and probably got a smoking deal on them to flog off. The 508 isn't there yet in that category though.
Edited by Chuck FB
Supposed to arrive next Fri'. I'm sure I'll be asking a few questions. I'm not really all that savvy w/ this stuff LOL
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
