Hey everyone, I’m having some weird electrical problems with my 2021 GMC 3500 Denali and hoping someone out there might have dealt with something like this before.
Background
I just had my truck deleted (DPF/EGR) recently. Everything ran fine at first, but right after the delete, I started getting a bunch of issues related to my headlights and turn signals.
What’s happening
  • My left turn signal blinks super fast and stays stuck on sometimes
  • My left headlight is mostly dead except for one small LED
  • When I turn on the left signal, my right headlight will blink
  • I’m also getting a “Service Charging System” warning
  • The shop that did the delete said it was due to a bit of condensation inside the left headlight and told me to replace the whole assembly
  • But I don’t buy that condensation was minimal, and the timing lines up exactly with the delete work
What I’ve done so far
  • Visual inspection of the headlight, no heavy moisture or obvious damage
  • Checked connections, nothing seemed loose or corroded
  • Haven’t replaced any fuses or swapped parts yet
I’m not super confident it’s a headlight failure, more likely something electrical got messed with during the delete. Has anyone else had similar issues? Any ideas on what to check next?
I can’t imagine the delete itself done properly causing those lighting issues, but if they disconnected things to do the work they could have caused it by not getting everything reconnected the same way. Maybe ask if they can tell you what wiring they disturbed in doing the work. If they won’t tell you, try looking in the areas they would have worked. I would especially look for loose or disconnected grounds.
Edited by Another JR
I took it back the day after the delete when I noticed the issue and they basically told me to kick rocks and to buy a new headlight
Background
What’s happening
Any codes?  Need something to scan all the modules.
it is probably the light, our 2021 3500 denali started having problems with the left headlight. the module that control the headlight is mounted on the bottom of the light and had water in it. there no cracks, so i dont know how the water got in. the fix is to replace the headlight. i did find later that you can buy the module separate on ebay
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
