Hello All,I just bought a 2020 Chevrolet Silverado LT.It only came with 1 key and 1 3 button key fob.It has a keyed ignition. I am trying to find the instructions to program a new transponder key,as well as the instructions to program a new key fob.
On my 17 silverado they cut a new key, with the old key I started the truck, turned the truck off and there was a short window to put the new key in and the truck learned it.
I would ask a locksmith before going to the stealership.
Edited by Hoginedgewood
Method required depends on generation of truck.
In some cases it depends if it was built for Can or US.
2020 Owners manual has this information.
2 hours ago, 20CHEVYRIDER said:
So I should follow the steps that says programming without recognized keys? Even tho I have 1 recognized key right?
Yes, if it was originally sold in the US.
I reads like if you have a truck originally sold in Canada, you need to see the dealer...
Edited by redwngr
Ok so I got the key cut today.I had a question about the instructions? Do I start with my original key or the new cut key I made today?
I was able to program the new cut key today.I started with the new cut key then programed the original key.
On 6/1/2025 at 2:03 PM, 20CHEVYRIDER said:
Ok great thanks for your help will try to get the key cut this week and try the instructions. What about programming the new fob?
Your dealership is in the best position to assist with programming another key for you, and they would be happy to help! If you'd like us to set up an appointment for you, email us at [email protected] and we can help. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 746 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
