1 hour ago, Tagrunt said:
I was thinking about having the dealership install a 2" lift kit on my 2024 Chevy 1500.  Has anyone done this lift kit ?
Good kit, all factory components from the Trail Boss.  Doesn't void warranty and they will reprogram a bunch of stuff as well to have things like the forward collision camera work correctly for the ride height increase.
You may have to add the rear spring kit if your truck has the composite mono leaf spring setup in back.  If you see 3 or 4 leafs in the spring pack, you don't need the additional spring kit.
...except if one has the Max Trailering package.  It would be cool if there was a workaround.
Excerpt from the description-
  • SKU:
    84993582
  • Positions:Rear
  • Other Names:
    Suspension Lift Kit
  • Description:
    Each system features front and rear passive monotube dampers specifically tuned to the chassis, jounce bumpers, rear leaf spring spacers and much more for fully integrated installation. An exclusive Front Camera Reconfiguration and an Electronic Power Steering Calibration is included, so that all driver-assist systems continue to function seamlessly. Read the vehicle’s Owner’s Manual for important driver-assist system feature limitations and information. Expert installation by an authorized GM Dealer is recommended. The 2-inch Suspension Lift cannot be installed on all regular cab trucks, 2019+ Chevrolet Silverado 1500 Custom Trail Boss and LT Trail Boss, all Max Trailering Package trucks (NHT), all Snow Plow Prep-equipped trucks (VYU), or any 2019+ Chevrolet Silverado 1500 equipped with composite rear leaf springs (Chevrolet LT Trim with 5. Kick the ride of your vehicle up a notch with the Chevrolet Performance Trail Boss Spec Lift Suspension Upgrade System. This Chevrolet accessory can help to personalize, customize, or optimize the capability of your vehicle for your lifestyle and use. Kick the ride of your vehicle up a notch with the GMC Performance AT4 Spec Lift Suspension Upgrade System. The only 2-inch Suspension Lift designed, engineered, tested and backed by Chevrolet specifically for the All-New Silverado 1500. Developed by the same vehicle-level engineers that built the truck, this system was tested under the same grueling conditions, and will not void the New Vehicle Limited Warranty.
  • SKU:
    84993582
  • Positions:Rear
  • Other Names:
    Suspension Lift Kit
  • Description:
That's because NHT Max Trailer has different spring rates and shock tuning for the added towing and payload.
I still don't understand why you can't add it to the max towing truck. It's only adding a lift block in the rear and not changing the spring rate. Different rated shocks maybe?
Allow me to quote my post right above
Removing the NHT bits alters the setup for NHT which would compromise it from its rated GVWR, payload and towing.
Edited by newdude
You're not replacing the springs, just adding blocks. Honestly just add a shock extender with the 2" block and keep the same shocks and it's all still the same except the height. Blocks DO NOT change spring rate.
AKA don't bother installing the GM kit at all on an NHT.  Some trucks do require rear spring swap (if it has the composite mono spring) but its still changing the shocks out regardless.
Edited by newdude
