So I started getting a wierd vibration in 6th at low rpm about a year ago, odd resonating; figured it was an exhaust noise (that's what it felt like too).  Fluid looks perfect, just changed it a couple weeks ago.  Turns out that odd resonation was probably the converter slipping...
So Monday it started surging in cruise.  I could control it if i didnt run cruise...all other gears seemed ok.  Get about 150 miles from home and I can tell it's the converter clutch slipping because it does it on a lugging pull in 3rd as well.  Drives fine when the converter is unlocked and if I'm light on the throttle.  Drove it back there (300 miles round trip) again Tuesday no change...
Funny thing is it only does it when lugging, it does it a whole lot less in tow/haul because it shifts earlier and its at a higher RPM.
Any idea on what I might be looking at cost wise for a rebuild?  Southeast Pennsylvania if that makes a difference...
Might be hard to say with labor rates and all that. But a new transmission from GM is probably around $4,200, just like the one in this link here. Prices may vary depending on dealership and such, then add labor.
https://www.gmpartsdirect.com/oem-parts/gm-automatic-transmission-assembly-19431754?c=Zz1hdXRvbWF0aWMtdHJhbnNtaXNzaW9uJnM9YXV0b21hdGljLXRyYW5zbWlzc2lvbiZsPTUmbj1Bc3NlbWJsaWVzIFBhZ2UmYT1jaGV2cm9sZXQmbz1zaWx2ZXJhZG8tMjUwMC1oZCZ5PTIwMTImdD1sdCZlPTYtMGwtdjgtZ2Fz
I can bet a rebuilt unit from a good transmission shop is going to run at least $3,000-3,500 then add labor to install. Going to guess at $100-150 an hour for labor, so add on another $1,000-1,500.
Around me there are a few places that advertise online and on marketplace that they do rebuilds for $2,000-3,000 but you have to do all the labor work of removing it yourself.
With that mileage if you pull it to do the converter it would be foolish not to rebuild it
I can think of a few thousand reasons ($$$$) it isn't.
What foolish advice. Anyone with any automotive knowledge knows the odds of any transmission life after 250K miles. Is a crapshoot. You’re already paying for R&R of the transmission. You’re changing the converter. A likely transmission failure is inevitable. So let’s trash the new converter with contamination and schedule time for the job again. And R&R the transmission. Sometimes people like to be contrary for no reason. Rebuilt the thing.
  • Like 4
Right now, looking at $4800 for a complete rebuild with all available upgrades, custom converter (same guy who did my ultra low stall for my old Dodge), and new computer (stops the converter from locking until 5th and 6th).
I didn't think that was horrible considering my 47RE was $3200 nearly 20 years ago...
  • 1 month later...
$4800
Custom converter with better clutch, new pump and pump mods, new sprag, all new bearings and bushings, new clutches, new valves in valve body, new plugs with orings, among other upgrades.
1-2-3 clutches looked good, 4-5-6 were worn but not bad.  It was the converter that was causing the issue and that caused the pump to wear.
Not bad for 252k miles...
  • Thanks 1
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
