Had the engine recall inspection today for my 2024 6.2l Silverado. Naturally, the  dealership says it passed (of course they don’t want to do warranty work) and when I asked about the extended warranty that I had read about I was told that’s not the case and I only had the remainder of the original factory warranty. Can this be right? Also, since I bought this truck I have had an intermittent multiple cylinder misfire. Several times a week the engine begins violently misfiring, sometimes even triggering the CEL to flash. If I pull over and turn the engine off then restart it goes away. I’ve had it in to the dealership twice now to check this, once back in April and now again today while performing  the recall work. Both times I’m told that they can see the P0300 codes in the history but but that because the CEL is not currently on and they did not experience the misfire themselves there is nothing they can do. Any suggestions on where I can find out about the warranty and what I can do about the misfire since the local Chevy dealer basically tells me to pound salt?
Check this posting on NHTSA:
https://static.nhtsa.gov/odi/tsbs/2025/MC-11019752-0001.pdf
Look at special coverage on second page. Here is the text:
This special coverage covers if an engine failure occurs in the vehicle as a result of the condition
described above for a period of 10 years or 150,000 miles (240,000 km), whichever occurs first, from the
date the vehicle was originally placed in service, regardless of ownership.
Edited by Tom73
Just had my '23 Silverado (7500 miles) test done.  Dealer said it passed no issue.  Upgraded oil to 0W40 supercar.
Fixed!  Right?
Dealer said I did get the extended warranty.  They also said every truck tested (5-6) so far has passed.
My '23 Silverado 6.2 with a hair over 25K is in the shop for the test as I type this. It has zero symptoms so I fully expect it to pass.
Silverado8810 - the recall notice you received from Chevrolet/GM advising you to schedule the inspection (same notice I received) states, in writing, (under the "What will we do?" section, paragraph 2) that the engine warranty is 10 yr/150K miles for this particular issue, if it passes the inspection/test.
Whover advised you otherwise at the dealer is misinformed.
The special coverage is extended for engine failure ONLY.
If you've got a bad plug or a coil or injector causing that misfire, it would only be covered under either bumper to bumper or regular powertrain 5/60 potentially, depending on what's causing the issue.
The 10/150k extended warranty is only for 6.2 engine failure.  So even after the new oil, if it locks up running or is knocking and spun bearings, they will replace the engine.  If you passed the test, you have this coverage.
Edited by newdude
yes, my understanding is the extended warrany is for IF it fails for that particular issue.
See post #2 above: “if an engine failure occurs in the vehicle as a result of the condition described above…”
I was told that if the vehicle was made in Canada and imported to the US, the extended warranty is void for the hundred thousand mile 10 year powertrain on the 6.2 L
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
