Hello,
What's the best after market magneride shocks/struts for my 2016 GMC Sierra Denali 1500 4x4.
I was wondering if any of y'all have used any of the cheep ones.
On 12/4/2025 at 11:52 AM, goat226 said:
Hello,
My research way back when mine needed to be replaced resulted in me not trusting cheap no name 'active' struts that were 'compatible' with the magneride system. Quality is a mixed bag and it's something I didn't want to roll the dice on. I also didn't want to spend the OEM price to get another mag suspension system I wasn't all that impressed with. So I bought a bypass kit (OBD port plug and/or sensor plugs) that allows you to install passive shocks/struts. This gives you crap ton more options depending on what you want to do.
I wanted a 1.5-2" lift and now I've gone through a few sets of various brands that gave me that. The best riding set hands down is the Eibach Pro Truck Stage 2 kit. It's 'plug and play' in that the coilover struts come pre-installed. Everything is bolt out, bolt in.
There are 2 versions, one without reservoirs (Stage 2) and one with them (Stage 2R). I got the Stage 2R and it's overkill as I don't off-road enough to need better heat control on the shocks. When these wear out I'll go with Stage 2 and save a few bucks. Since the OEM mg ride shocks/struts were about $1600 to replace I saved around $400 doing the bypass and getting a passing kit. The Eibach rides incredibly well, not too soft or firm.
BSI Manufacturers them.
If you look them up through gms parts site and scroll down you will see that they have a "limited lifetime warranty, parts plus labor". Good luck finding a dealer to honor it though. That lifetime warranty only covers labor for 2 years though.
I was able to get only one dealer in my area to warranty my parts but still charged for labor which was stupid expensive and I otherwise would never have paid it. But now I have another 2 years of complete warranty for what I would have paid for the parts alone.
Last time I looked rockauto had the best price at around 450.00 per shock/strut (factory ones, with the warranty).
GM Genuine Parts Front Shock Absorber | 84977478 | GM Parts
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
