Gregory Krisa Posted December 27, 2025 Posted December 27, 2025 (edited) Hi just got my truck back from shop for new transmission and now the truck some times wont start seems like bad fuel pump. i have lots of codes my guess is bad ground im here to get another opinion. what should i do? shop doesnt open till tuesday. thank you P1682 ignition 1 circuit 2 fault U0422-71 invalid data from bcm U0029 poor can bus performance B1024-53 driver airbag short to ground b2575-04 left headlight open b2699-04 right headlight open both headlights are working fine i do have aftermarket hids with capacitors C0765-29 C0760-29 both are tpms yes there dead B127B-2B reverse camera signal missing stinger aftermarket radio should still have signal? Edited December 28, 2025 by Gregory Krisa
richard wysong Posted December 28, 2025 Posted December 28, 2025 Check the ground wires on the top bellhousing bolt and the rear of the passenger cylinder head 1
Gregory Krisa Posted December 28, 2025 Author Posted December 28, 2025 thank you. at -40f this is a problem finding the rear of the bell housing.
davester Posted December 28, 2025 Posted December 28, 2025 From R&Ring the transmission on my '04 3500 w 6.0, I didn't have any ground wires on the bell housing bolts. top center is for a bracket holding vent tubes, next bolt over to the driver's side is for the fuel/evap lines bracket, to the passenger side is the brace for the trans dipstick tube. What's the point in asking if it's too cold for you to work on the truck? Were you hoping there was a switch in the cab you had to flip to make it work? If the truck just had the trans replaced, and these problems weren't happening before, but are now, then, most likely, they are related to doing that work. So, some wiring harness is getting pinched, or not fully plugged in, or similar. So really, the starting point is getting the truck up, and crawling underneath it to see what's up.
Gregory Krisa Posted December 29, 2025 Author Posted December 29, 2025 options. well thankfully i know where to look but trying to squeeze my hand in there and feeling around is not working right now as its too cold maybe before my check in appointment it will warm up and i can find it or i can get lucky. january 6 they were going to check for leaks maybe. there is a note on the paper work that they may have a immobilizer installed. i couldn't find anything. the can bus performance issue could be poor communication to transmission module.
Black02Silverado Posted December 30, 2025 Posted December 30, 2025 How old is the battery? That can cause issues as well. 1
MikeBMW Posted January 1 Posted January 1 On 12/30/2025 at 2:37 PM, Black02Silverado said: How old is the battery? That can cause issues as well. True. I had a relatively new battery and, at times, I would forget to turn off my dash cam while at home for a few days. The radar detector would shut off on low battery sensing (Uniden R8) but my dash cam (VanTru N4) would keep going and deplete the battery. I replaced with an AGM and, lately, on the occasion I still forget, it (the battery) keeps going. No more bringing out the MaxiSys to reset all of the codes after a battery low issue triggers all sorts of temporary codes. Now, I just do it for fun to reset transient temporary codes from time to time.
Gregory Krisa Posted January 1 Author Posted January 1 battery is about a year old agm i have a battery shunt says its 100% charged. there is a possibility its it the ignition. how often does the ignition go out on these trucks? 1
doropallo Posted January 1 Posted January 1 What year is your truck? My 2016 Sierra had issues that I was able to clear up by replacing the negative battery cable, cleaning the connections of course. You need an oem replacement for this. But first, if I had work done and then had problems I'd be all over that shop blaming them. 2
Register a new accountSign in
