But will the 2027 Silverado have automatic stop/start force-enabled? Or will GM give consumers the option to leave it off?
I'd bet that they were developed with it, and it will be defeatable just like they are now, with a switch on the dash.  The ability to leave it off all the time, anything is possible.
The only thing that has changed is the credits went away from the EPA.
Edited by newdude
On 5/14/2026 at 1:10 PM, Atlas said:
About the only extended cab I'd take. Crabwalking before it was cool. In the picture the rear steer angle is opposite the front to decrease radius, but they would also track with the front when changing lanes at speed. Another GM design way ahead of its time.
Its a shame the updated for 2005 version never hit the market as they shrunk the axle width out back to make it fit with a standard sided box instead of the 1/2 dually flares.  Of course I can't find the picture right now, but it was a red crew cab short bed behind a fence with the rear wheels turned and everything.  The price supposedly was cut as well.
The Silverado EV/Sierra EV/Hummer EV 4 wheel steering works great though.  And is the same principle as the old Q-steer, just modernized.  Less complex since its IRS out back for suspension, so its like designing the front but for the rear, instead of a rack mounted to a diff cover of a Dana 60 like Q-steer used.
Could the narrower version still get 48" between the wheel wells?
Honestly, not sure.
Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
This thread started March 5th.  That was one week after that date for the GM dealer conference in Las Vegas, and dealers attending did see the new Silverado.
So no, no reveal "next week", but there was a showing in March to dealers.
Probably not at this time on the HDs. They are usually 1-2 years refreshed behind the 1500s. I'm really surprised they have not at least shown something of them yet. It's only a few months left before the new model years hit the dealer lots.
And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,301 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
