Tires
14 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
She is starting to come together.
1. Window Tint
2. Running boards  (So my old ass can get in.)
3. MX4 bed cover
4. Husky Bed mat.
Edited by GAMark
Of those three tires, I'd say the Bridgestone AT, I've had problems in the past with the original BFG AT and KO2.  Recently I've ran two sets of Cooper LTX AT3's and now went back to Michelin, you just can't beat the quality of a Michelin tire.
The problem I have with Michelin is that they suck in most conditions off-road. And can share one story where I was running them pulled off to read a map, yes, I am that old, and the tires would not move my truck even in 4 wheel drive. This was in the winter, and it was cold as hell while winching the truck back onto the road. I said to myself that day I will never run pure street tires on my truck again.
Edited by GAMark
1 hour ago, GAMark said:
The problem I have with Michelin is that they suck everywhere off-road. And can share one story where I was running them pulled off to read a map yes, I am that old, and the tires would not move my truck even in 4 wheel drive. This was in the winter, and it was cold as hell while winching the truck back onto the road. I said to myself that day I will never run pure street tires on my truck again.
I hear you!  A good All Terrain (AT) tire works best for most people, Michelin makes an AT tire, but it's pretty mellow.  That is why I switched to the Cooper AT3 LTX tires.  I did have one fail in the middle of nowhere Montana, but it was from the first run of the tire and carrying a heavy load in 96-degree weather.  Photo of tire still holding air.....
  • Confused 1
My 2024 AT4HD came with OEM BFG KO3's, probably a little different than the ones from a tire shop. I like them for mid-April to mid-October. I run a studded snow tire on GM wheels for the other 6 months. I just swapped them over today.
I'd replace the KO3's with another set when the time comes.
The new Michelin LTX MS2's if you can get them are some of the best on the market now for a on road and light off road. My work sells those like nobodies business in the winter time here, by far the best selling tire here.
Of the ones you posted I'd go Falkens. Or look into the Toyo Open Country AT3's if they have your size, great tire. Have them on my parents Silverado.
I've heard a few shops mention that BFGs are good on traction and wear, but are a ****** to balance, and you must constantly rebalance them over their lifetime.
Every tire I've tried other than BFG All-Terrain has been a let down at best and disaster at worst.
Actually, every tire other than BFG has been that way.
I know they (BFG) are owned by Michelin - but every Michelin tire I've had has been a disaster of one form or other. I won't buy them and tell everyone I know the same.
Bridgestone Dueler A/T Ascent
 Installed this morning.
Edited by GAMark
  • Sad 1
Not one of the 4 tires was over 12 on the Road Force machine.
Personally I wouldn't run that tire - I only run snowflake rated tires, even if I might still run dedicated snow tires part of the winter.  KO3's are at least snowflake rated - they may not be fantastic in the snow, but they are decent for at least the first half of treadwear.  The OEM versions ride quite nicely IMHO.  I had a set of KO2's on a Colorado and had no issues with them other than getting a bit loud as they wear past halfway.  I also had the cooper 4S and won't run that tire again - not nearly good enough in the snow, and not very good at all offroad.
The Bridgestone Dueler A/T Ascent is a premium, all-terrain tire designed for modern SUVs and light trucks, balancing rugged off-road capability with a quiet, comfortable on-road ride. It features a unique sawtooth tread design, 3D sipes, and is 3-Peak Mountain Snowflake (3PMSF) certified for severe snow service.
OK thanks - good to know - the website didn't make that very clear.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
