Has anyone found a Cat Back Exhaust that does not drone when towing?
Edited by GAMark
I was fortunate enough for many years to know a custom exhaust bender. When cross over exhaust became a thing is when drone showed up. Uneven exhaust sounds the best in my opinion. They have all kinds of tricks now to eliminate drone. I saw a demonstration where max HP was achieved with single exhaust. Most modern factory exhaust flows to achieve max rated horsepower without intake modifications or additional tuning. The last exhaust I did I simply changed the muffler leaving the resonator to increase sound without drone. My last performance truck I did true duals without the cross over, loud no drone. If you go with most any modern cat back. It will sing while pulling. There’s loud than there’s drone. One sounds good the other doesn’t. If you have access to an exhaust shop I’d start with a different muffler, just the muffler. You could spend a fortune to eliminate drone.
My understanding is a properly setup "J pipe" will eliminate the resonate'n but, I don't understand the math to it.
Also more accurately known as a Helmholtz resonator.
Edited by OS RR
I have a dynomax cat-back on my truck, been on it for probably 7 years now. You can barely hear it on the freeway and when I tow my 20ft car trailer. This is on a 2016 Silverado though, newer trucks to me are quieter on the inside compared to mine.
I believe the J-pipe causes a 180 degree phase shift in the frequency that causes drone. Doing so cancels out the sound.
I installed a Borla S Type on my 24.  I love it and have no drone, at highway speeds cruising you can barely hear it.
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
