I have a problem with my truck completely shuts off and comes back on when im driving and I go over bumps. All my connections to the battery and starter secure. Really at a stand still can't figure it out
Check the securing nuts on the power distribution cap. I saw a video a while back where on of the power line terminals was loose causing this issue. Another thinking is to check you grounds. A couple of videos on YouTube showing them. Check the simple things first.
https://youtu.be/LPiBKMJ5Lb8?feature=shared
Edited by rav3
We recognize the importance of being able to rely on your Silverado, Rob81. Your safety is our top priority, and we would like the opportunity to work alongside you and your local Chevrolet dealer to pursue the resolution of your truck stalling. To proceed, please visit: https://s.chevy.com/support-request  and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately. We will be on the lookout for your outreach.
  • Haha 1
You guys won't do anything.  You will make him pay a $250 diagnostic fee and hopefully try and find the issue.  This has been a known issue with these trucks.  If GM says safety is a top priority then GM would make this a recall or some special coverage like the vacuum pump issue.
That GM customer service is an AI bot, don't expect a response
  • Sad 1
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
