2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck
I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one
#1   Since we have owned our truck purchased new it has this strange noise after using the remote start function
you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .
There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of
#2  You can only hear this if you are standing outside of the truck and near the truck
you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally
#3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again
I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it .
Now its back in the Dealership left it overnight so they could possibly hear the problem .
They said they tried and nothing happened . Well they did not know what they were listening for .
I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership
Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like
Really  would like to know if this is anormal sound
Thank You Fellas !!
Oil pump noise was discussed before.  I will try to remember to record a remote start later this morning.
Thanks JR that would be great if you could do that !!!
Do you have a link to where this was discussed before ? I cant seem to find it
Thank You Again !
Thank You Again !
My plans changed today so I haven’t had a chance to record a start yet.
This is one of the threads I recall, but you were involved so maybe you already reviewed this one:
Thank you JR !
Whenever you have time to record your tucks starting it will be appreciated !!
I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
I usually upload to youtube then paste the link here. I haven't done it here but it worked on other forums.
Thank you JR ! Here's hoping you can post the video with sound
JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !
Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do ,
I will see if I can find it and post it up
Here we go JR and others this is exactly what my truck does
Mine makes the same noise on cold starts. I'm pretty sensitive to weird noises (check out my post history 😁), but I assumed this was just normal.
Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
Next time I start mine up, Ill listen but I dont think I have ever heard that noise before.
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
    • Gloss black would look better, but I'd paint match the grill before ditching the chrome bumpers.
    • Mine has done that since new. The colder the worse.
    • Yeah, that's my understanding. The newer trucks are 433Mhz vs the older 315Mhz TPMS. Putting these wheels on is costing me a small fortune, but so far, I'm still OK with it.    Next week the chrome bumpers are scheduled to be replaced with flat black ones. That would complete what the dealer still owes me.
