Excuse my stupidity, I have a 2016 High Country with 6.5’ bed.  I want to pick up 1/2 CD wood which might be 1000-1500lb.  Can the truck handle that?
And Google AI says.........
Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
Thanks for the suggestion, but they do not give that information.  I see GVWR etc but have no access to a scale to know empty weight.
It sure does. You have to look a little closer. This is mine.
And I just realized you have to do one more step. Both labels are important. The GVWR in mine is 7200lbs. So that would be the weight of the truck fully loaded correctly. Take that weight and subtract the 1602 lbs for mine (combined total of all the added stuff) and I come out to 5598lbs empty. I hope that helps get you pointed in the right direction.
Yep, I just looked at my door sticker on my '17 1500 silverado double door & mine will carry 1981#
OK, that really helps.  My 6.5’ bed HC sticker says 1,359 lbs., didnt see that small print.  Subtract me and some stuff, gives me about 1150lbs.  So based on Google for hardwood (1500-2000 lbs), I’m making 2 trips for the 1/2 cord.  Problem solved, thanks.
No one likes a showoff, LOL! 🤪
    DLZ
    DLZ
  • Who's Online   3 Members, 0 Anonymous, 566 Guests (See full list)
