Does anyone know what the 05 HD's will look like?
DuckhunterInTN
yep I have my background on my computer set to it. I found the pics somewhere on the internet of a red HD
To quote CDN111 on that forum:
Got this from thedieselplace.com. Says it's a pic from Gm Argentina's website. Not sure that it will be the new 2500HD/3500 but the way Chevy has talked it sure looks like a good possiblity.
I'm calling :banghead: on the Argentina part. I have looked up and down on the site, and I cannot find any mention of the truck in question. The only trucks that they have down there are S-10s and Blazers that look somewhat different than here in the US. Those, and the Isuzus and Suzukis, but no mention of the Silverado LD or HD.
I saw a s10 at the houston car show once that was a crew cab dually 5.7L. Looked pretty cool in blue. I think it was south american....
That would be the 2001 Chevy S-10 Xtreme +4 Concept.
Here is the main link for it. ---> Clicky
That picture is truely an offical GM picture...
Just see our main page for the 2005 preview image.. we use the same one.. :cool:
Sweet. Good info. Nice upgrade but nothing really enough to make me want to hold out for an 05.
It looks to me that the side profile of the frontend didn't change any (except the raised hood) and the way the grille looked from the side view was the only thing that I sorta didn't like...
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
