need help with trans fluid change
im in need of a trans fluid and filter change. i do a decent amount of towing so was thinking of using a synthetic fluid. what brands are good and how many qts. does a 2000 2500 w/6.0 4x4 hold? thanks
Welcome to the Forum :jester:
Fluid amount depends on which tranny you have, a 4L60E takes about 6qts on a normal fluid and filter change,if I remember correctly. But your owners manual should give you the correct info for your truck....As far as fluid brands, I can only tell you that I've had good luck w/ Castrol and/or Valvoline I've used both without incident
It really depends on where you go to flush and fill your transmission. The dealer here in Colo Springs does not drop the pan and change the filter. The do a "back-flush" using the cooler lines. I don't like the idea of that process, so I went to a transmission shop that has the flush and fill equipment, dropped the pan and replaced the filter. The flush and refill took approximately four gallons. I took in my own Amsoil ATF and have been very happy with the results.
I tow on a regular basis all over the Colorado mountains without a worry.
Cheers, Doug
If you just drop the pan, you will drain about 5 quarts in a 4L60E, which is the transmission in the 1/2 ton 4WD trucks. If you just drop the pan and change the filter there is no point in putting 5 qts of synthetic ATF into the system of 12 qts. You'll need to get the tranny flushed to make the switch.
That is what I'd like to do also but have not found a place that can/will do it on an Allison tranny.
i thought all trucks have the 4L80E and the cars have the 4L60e. i bought my truck used and dont have the owners manual.
You can check the RPO code sticker in your glovebox,if you have a 4L60E you should have a M30 code, a 4L80E would have a MT1 code LOOK HERE
As far as the fliud flush mentioned above, that would be a better option if you want to convert to synthetic, but the filter should also be changed, otherwise whats the point? Besides I would rather drop the pan and take a look-see for any tell tale signs of excessive wear (metal shavings for example)....just a thought
i installed a drain plug in my pan.5 dollars at part store.i changed the filter then put in 5 quarts of fluid . i drove for 3 days then opened the drain plug out came 5 more quarts and i put in 5 clean quarts. i know this is not a perfect way to do it but i dont want to mess with cooler hoses etc. every year i go under open drain plug and put in 5 fresh quarts of fluid.takes about a minute to drain and in goes new stuff.mechanics here said thats way they do it.take care. :puke:
    • After my recent rear end bumper damage, body shop has made the repairs and included a new OEM receiver hitch.  I started thinking about how it was tightened...to specs or by hand or ??.  I called the body shop and asked and they said it was tightened by an impact gun.  I said I wanted it tightened to OEM specs.  They said no problem, bring it to shop today and they will torque to specs, which they say is 74 ft/lbs.   A couple of questions,,,,   1.  Should new bolts have been used?  If so, how many are there (bill shows one and four (I assume different areas of receiver).   2.,  Since they torqued with impact gun and now are going to probably loosen and then torque to spces, will that damage/stretch the bolts?   3.  If old bolts were reused (truck has 9000 miles), is that a problem?   4.  Any other things iI may have missed with regard to receiver replacement?   Thanks!
    • Is this supposed to be in English?  "close to 100 fake, new brake pads sign on the dash board"     Pull the wheels off.  Check the brake pad thickness.  Check the sensors out.  You could have good pads and the sensors aren't in to the worn out position, but have an electrical fault with the sensor or the plug wiring to the sensor.
    • Gas or diesel???????????   You did not indicate.  Your topic just says "2022 10L80".
    • Tomorrow I go in for my third joint replacement in jus a little over a year year!  I am not worried about the surgery but I am a little annoyed about going through the recovery process again!  I keep my frustrations to myself as I do appreciate that I am truly lucky.  Knee, hip, and shoulder replacements are routine, safe and improve mobility.  The next couple of days will be slow but every day following will see steady improvement in my mobility.
    • Practical Application ISO 4406   I think this oil cleanliness thing is going to boil down to ones personal resolve. The information is there but applying it I believe will test your commitment to the machine. Implementation would involve building or buying a prefilter or purchase of an "ISOCLEAN" oil. Then installing a single digit micron bypass system. A good deal of testing and about 99.9% of you are saying at that point....yea.....not my cuppa tea. So what can you do?    You already did the first step. Get educated and leave the bias at the door. Be aware of the its, cleanliness, importance.    Do your own work if you can. Keep the equipment clean. Not just your funnel but the engine bay. Use sealed containers. Think it through.    I believe you will find, as I did, that the tightest absolute full flow filters (Beta 200) will be around 20 micron. That will yield on average a Beta 75 of 10-15 micron. They are few in number by brand and price point. Loose filters are a dime a dozen and even the best brands have lines of loose filters. Some cleverly marketed as "Extended Service". Others will market flow over efficiency. But I think the take away once informed is that the extra cost of the best offered is a bargain. There are cheaper filters with good efficiency that are equal in performance to niche brands with big prices. Your Quick Lube is about a 40 micron unit. This is where your dealer is a plus. the AC-Delco filter is a good step up from those places. Even better if you specify the UPF line.    Be skeptical of marketing. Buying an oil that is made from GTL advertised as the cleanest base oil is using a truth to support a lie. While GTL's are made from debris free gas the processing equipment and post handling is just like any other oil. It also ignores the fact that PAO's and Esters are also gas in origin. Any private prescreening testing you would do, and some have done, would yield a result only good for the batch you tested. AMSOIL and Schaeffer's have built a reputation for paying attention to this detail.    Context. Cold starts account for at least 75%, or more, of an engines wear. But of the remaining 25% ish, over 80% is caused by particle count. Now where do we find high milage motors that use this type of information efficiently? OTR trucking!      Now, anyone want to build a prefilter or off line cleaning system anyway?
