New Vehicle
RyanbabZ71
Well today I got a new vehicle (well 2 :) )
2000 Chevy Impala, goldish/beige color, 3400 engine, power/heated leather seats, 51K miles. Pics to come soon.
This car is going to be my gfs weekday car to drive back and forth to school/work. I am going to be taking her 93 Escort to work and on weekends and trips I will b taking the impala.
no I didnt sell the truck dont worry. Between me and my gf we have 3 vehicles :)
93 Ford Escort - mon-fri work car for me, weekend work car for her
00 Impala - mon-fri work/school car for her, weekend car for me
00 silverado - all week mine whenever I need it. Basically a pleasure/work vehicle now. Take it fishing and do any hauling I need to do.
cool very similar to my parents' Impala. My dad is wanting to find some used Impala SS wheels to put on it, I gave him the idea when pointing how that most people buy the "impala SS" to put big shiny wheels on with a expensive stereo.
hey snakeeyes do you guys have the trip computer in your car? For some reason I am getting 0C for the temp. Do you know how to calibrate it? I dont have a manual
Thanks
Thanks
nope, sorry, ours dosen't have one.
but from my overall car temp experience, you might need a new sensor, or it has become disconnected.
The sensor on my dad's 325iC is missing, and it reads -27C......BURR :thumbs:
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
