DSL
Black02Silverado
OK here is the deal. We have been on dial up since 1993. Same internet provider. So you can imagine how indepth our e-mail address has gotten with everything we have ever done online and people we know. Anyway, I was just informed that DSL is coming to our little (population 500) town. Every other town around us has had it for a few years now.
Since it is the only high speed available and I will hopefully be getting, Can't afford DirectWay and cable isn't available, what do I need to know as far as little tricks to fine tune it once I get it. Keep your fingers crossed that it gets here with in a month. Sprint has been telling me that for 2 years now. But I found out from the Sprint repair guy that was here to trouble shoot a problem with our line, that the equipment is being installed in our towns phone building this week.
Thanks
Put the little DSL filters on EVERYTHING. We kept having a problem until we found out that there was no filter on our alarm. Use a DSL patch cable instead of a phoneline, and make it as short as possible. A while back we had a phone jack problem and we had a phone line running to another room. Our connection speed was only like 500k but as soon as we got it fixed and got a patch cable it went back up to 1.5mb. Make sure you get a modem with an ethernet connection. This allows you to set up a router later on. When we first got it about 3 years ago somehow we got stuck with a USB connecting modem. Bellsouth thinks that modem is broken now....
GET RID OF INTERNET EXPLORER!!!!! pull up a link to Mozilla Firefox smf download it. got rid of my IE and it's one of the best things i've done. get a good firewall software as well as a good virus pkg. i use a little pkg calle Privacy Erase Pro. it removes ANYTHING/EVERYTHING of where you have been on the net. you have no record in your system and nothing to track where you were on the net itself.
Its probably because I upgraded to 0.9.3, on 2 computers here it wont keep the bookmarks.
Now Im using Mozilla on my Linux machine and I love it. Im using Mozilla 1.7.2 on Redhat 9.
Make sure your close enough to your CO before you go through all the hassle of trying to get DSL. Its something like a 1 mile or less. CO is the Central switching office for the phone company. Every town pretty much has one. As for tweaks get your self a router/firewall box for like 30 bucks at best buy. This will help block anyone tring to get into your computer from the outside world.
Thanks, I'm only a few blocks from the Sprint building. So I should have great speed. Nice to live in town, even if it only 500 stong. I also have Firefox. It works great for me and keeps my favorites no problems there. I have linux on this machine but to scared to boot to it. Maybe one day I will venture on it.
Thanks again
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
