Well I have been looking for a center console for my truck, and I have found that the dark grey color is pretty hard to come by, however there are tan and light grey ones available. I have head the these can be Dyed to match my interior. Has any one done this???? :lol: If so how durable is it, how complicated, and how did it look??
I had to have a dashpad replaced due to damage from a shotgun blast on a '92 Yukon once. The new one from GM was dark grey, they dyed it burgandy. It looked very good and was very durable. It was a simple process. Just make sure to go with a good quality dye and follow the directions to the letter for proper preperation and temperature application. If it gets scratched you can always touch it up.
Dennis
Truck is a 2004 Sierra. I need the center console that is common on the extended cab trucks. It goes from the center of the seat all the way to the dash. Truck currently as the fold down center seat. The dealer wants way too much money for the console, I can get on off e-bay for much cheaper, but I can't find the darker grey color, most are tan or light grey. From what I understant the dark grey ones are very hard to come buy since they are the most common color used in the trucks.
I have the center console in graphite it is the one with the cup holders front and back with vents for the backseat and large console, its out of my 01 2500HD CC. it goes all the way up to the cigerate lighter with the tape deck (mine doesn't have the tape btw). Anyway if this is the same piece you are looking for.... I need the part under the cigaret lighter that has the fold out cup holders in graphite?
Your jump seat folds up and down does it turn into an armrest for the driver and passenger....is it cloth?
Josh
Josh
yes that is what I am looking for, but the 01 does not quite match up to the 04 model. GM changed to dash area a little. I do have a lead on a light gray one for the 04 model year. I probably am going to pick it up, I just have to find someone to do the dye work on it. Finding the graphite color is impossible.
As for your question about my center seat, yes it is the fold down type in cloth, but the top is some sort of vinyl(the area where you would rest your arm)
You can do the dye work yourself it comes in either an aerosol (or use too) and a bottle with an applicator like a bottle of shoe polish.
    • Thank You Another JR, I watched the transmission temp the highest was 214, the engine temp seemed normal.  Hoping not a valve body issue, but...
    • dexos began as an effort for GM to control the oil change market because the Quick Lube Industry was eating into dealer service department profits big time. So they attempted to get other oem’s to develop standards as well and that would make it hard for Quick Lubes to compete because all the oems would be different. GM faced lot of industry push-back, mostly the quick-lube industry and they went to licenses. Still GM it making a ton of money (est'd 30-40 million in 2025) off the license structure as they charge a hefty fee to get oil tested then require a royalty on ALL gallons sold applicable to GM vehicles.
    • Those are parts changers. It can get expensive though. I was a mechanic for 30 yrs. My truck has made this noise since new. I really don`t know what it is. It really doesn`t bother me. I`m still in warranty but have not brought it to the dealer.   I`m not buying the oil pump prime thing. Screw the TSB. I believe it`s in the trans pump gears. They rattle when that piss poor ULV oil drains off after a while. I believe those sharp tooth gears, with backlash, can rattle when dry. Not a vane style oil pump. Wonder who`s right? Me, or the TSB?🤔   Maybe I`m wrong?
    • Sounds about right. I miss the days of mechanics lol.
    • On the PCM side, blue PCM connector, pin 18, solid gray color (no stripe) wire circuit 435.  That is the EGR low circuit which an issue on that line (be it the wiring, the PCM or the EGR valve or system performance) will trigger P0401 when it tests that code.     There is also a VERY old TSB that states to make sure you clear the DTCs ANY time the PCM is unplugged, reprogrammed, or if the EGR valve is unplugged or replaced as the PCM has an auto zero function in the PCM for the EGR pintle data   61-65-59: SMU - SECTION 6E - ENGINE CONTROLS - CLEAR DTC'S - (Nov 25, 1996)   "CLEAR ANY DTCS FROM THE VCM ANYTIME AFTER DOING VCM REPLACEMENT/ PROGRAMMING, TURNING THE IGNITION ON WHILE THE EGR VALVE IS DISCONNECTED, OR REPLACING THE EGR VALVE."   Some diagnostic aid notes in the GM diag on P0401 for a 1995 S10 Blazer:   Diagnostic Aids Notice: In order to prevent further damage if the EGR valve shows signs of excessive heat, check the exhaust system for blockage (possibly a plugged converter) using the procedure found on the restricted exhaust system check. If the exhaust system is restricted, repair the cause; one of which might be an injector which is open due to one of the following reasons: Stuck Grounded driver circuit Check the oil for possible fuel contamination if a stuck open fuel injector is found. Poor connection or damaged harness - Inspect VCM harness connectors for the following conditions: Backed out terminal BL 18 Improper mating Broken locks Improperly formed or damaged terminal Poor terminal to wire connection Damaged harness Intermittent test - If connections and harness check OK, monitor a digital voltmeter connected between terminal BL 18 and ground while moving related connectors and wiring harness. If the failure is induced, the voltage reading will change.
