6.0 vs. 6.0HO
I was lookin on chevys website and they have 2 6.0's listed. A regular 6.0 and a 6.0 HO. Is the 6.0 HO a special option cause it says it has 45 more horsepower and 20 more ft/lbs of torque. I looked in my glovebox and found out mine has the regular 6.0 with a LQ4. How many of you have a 6.0 HO, its code is LQ9?
yep, the 6.0 HO is only found in the Silverado SS, AWD Escalade and Denali. It can be ordered in the ecsb silverado as a special order. I almost bought one of these truck at a dealer out here in CA. It was a spiral grey LT truck with the factory 20's and sport suspension with the 6.0HO....almost like a 2wd SS pretty cool but I wanted 4 doors...
I believe so. The one I was looking at was called the California Performance package with the sport suspension, ugly 20" wheels, LT interior, and the 6.0L HO
The HO is also in the 3/4 ton Suburban/Yukon XL. I have the motor in my 04 Yukon XL 2500. It has good zip, that's for sure.
What exactly is the difference between the two 6.0s?
How does GM get additional power from the HO?
Can these changes be made to a std. 6.0 to make it into a 6.0HO?
I had a friend that worked at a dealer a few years ago, and he claimed it was different heads & cam. Is he correct?
From what I understand the difference mechanically is small, just different pistons for a bit more compression. The rest is all in the how the PCM (Computer) for the vehicle is tuned. A custom performance tune would give you an additional jump in HP & TQ if you are looking for more power out of your 6.0L. I run a Westers custom tune on my truck and I am happy to be rid of the mild factory tuning...
Check your RPO codes in your glove box. I bet you have the LQ4 and not the LQ9 HO. The 2500 Burbs with the LQ4 6.0 are rated at 320HP as opposed to the LQ4 6.0 300HP in the 2500 trucks. The Denalis also got the LQ4 320HP up until 2004. The Denalis now get the 345HP LQ9 6.0.
I have a LQ9 in my VHO truck and a LQ4 in my 2500 Crew Cab.
Yes, you're correct, it's the LQ4 motor. So I guess it's not the High Output but rather the Higher Output (but not as high as the HO)? Seems the 6.0 is available in several output versions. You'd think they'd give them different designations. The GMC website lists the 6.0 at 335hp for the Yukon XL 2500, for example, but that's apparently not the official HO version.
Whatever the case is, the "higher" output 6.0 in my 2500 YXL is a pretty peppy motor and I'm glad I have it.
The new 6.0's found in the Three Quarter ton Suburbans and Yukons XL are rated at 335 Horsepower 375 ft lbs of Torque, it says so in my CD that came with my brochure i got from Chevy. Chevy should put this engine in 2500 HD trucks in my opinion!
Supporting the Sierra Crew Cab Denali’s professional grade capabilities is the powerful Vortec 6000 6.0L High Output V-8 LQ9 engine. The LQ9 produces 345 horsepower (257 kw) and 380 lb.-ft. (525 Nm) of torque. It’s more powerful than any engine previously offered in a Denali model and boasts numerous technological innovations, including electronic throttle control, which does away with the traditional mechanical link between the gas pedal and engine throttle to deliver crisp, more immediate throttle response.
The Denali Crew Cab gets the LQ9 and the Yukon Denali and Denali XL keep the LQ4.
Yukon Denali and Yukon XL Denali’s Vortec 6000 6.0L V-8 (LQ4) engine also receives an increase in horsepower and torque, thanks to new, improved-flow cylinder heads and optimized fuel and spark calibrations. Also, the addition of dual electric cooling fans reduces engine drag compared to an engine-mounted fan. Horsepower jumps from 325 (242 kw) to 335 (250 kw) and torque increases from 365 lb.-ft. (495 Nm) to 375 lb.-ft. (508 Nm).
The below information pertains to the Yukon XL 2500 and the Chevrolet 2500 Burbs.
Engines
Vortec 6000 (LQ4)
Type:
6.0L V-8
Displacement (cu in / cc):
364 / 5967
Horsepower (hp / kw @ rpm):
325 / 242 @5200 RPMs
Torque (lb-ft / Nm @ rpm):
365 / 495 @4000 RPMs
The below pertains to the 1500HD Crews and the 2500HD Silverados/Sierras
The Vortec 6000 6.0L V-8 produces 300 hp (224 kw) and 360 lb.-ft. (488 Nm) of torque. LQ4
I found all of this info on the GM Media site if anyone wants to check it out. This all pertains to the 2005 Model year.
http://media.gm.com
Engines
  Vortec 6000 (LQ4)
Type:
  6.0L V-8
364 / 5967
Not according to the GMC Website:
Yukon XL 3/4-Ton
MSRP $41,380 - $49,160^
A choice of powerful engines, including, Vortec 6000 V8 with 335 hp and 375 lb-ft torque
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
