Replacing factory stereo...
I'm considering swapping headunits in my truck, from an OEM single CD to an OEM trailblazer 6 disc in-dash unit. My truck does not have bose speakers or amp, but this headunit has bose written on the front of it, so I assume it came from that setup. Will this cause any problems with the install into my truck, or with the Infinity Basslink I plan to install later? I know I need to have the unit programmed for my VIN, but do I need any adapters to make it all work :confused:
Will this cause any problems with the install into my truck, or with the Infinity Basslink I plan to install later?  :confused:
Yes, you can't do it, unless you use aftermarket amps, or a oem bose amp..
