"Creaking" drivers door - anyone else have this?
I have a 2004 GMC Z71 which I bought new and now have 24,000 trouble free miles on. The only complaint I have is a "creaking" sound coming from the drivers side front door (extended cab, not quad quab). It sounds like something coming from the hinge/pillar attachment area. This also occurs while I am driving the truck, not opening/closing the doors. Any bumpiness in the road surface, accelerating or stopping causes it. I haven't doused the hinges yet with penetrating lubricant, I'll do that next. Anyone else had this on their truck? Thanks for any help.
I remember a post about this from a few months back. Try searching in google for "site:gm-trucks.com armour all squeak".
Besides the hinges, the door check (black guide between the hinges that limits the angle of door opening) can also be the source of annoying creaks or squeaks. I had that happen on my Mazda 626. Sprayed some WD 40 on it and the creaking went away. Mine only did it when opening/closing the door.
Hey sshoureas,
I mentioned this in a post some time ago. Yes, I have exactly the same thing on my 05 silverado. It does it mostly when cold out side and its coming from the door pillar at the top near the latch(I think), very annoying indeed. Must be some
GM fault as a few people are getting it. I tried the WD spray and did not work. Not sure what to make of it. I wish someone could track it down.
Stay in touch
At the risk of being repetitive :eek: take it to the dealer. Free warranty.
GM has some pretty good lubricant for dealing with these issues. Don't use WD-40.
I had the very same problem on both a 2002 and 2003. Both times I took it back to the dealer and they were able to take care of it under warranty. They never let on what it was but at least they stopped it.
I bet I know exactly what it is... It is the Door Skin. I had the same thing on my 2001 Tahoe... even if I rested my arm on the armrest and pressed hard I could make it creak...
The resolution was simple...
I pulled the door skin off. The skin literally hangs on the door with a bunch of plastic "Hooks".. The noise was coming from the hooks scraping on the sheet metal door.. I took some duct tape and wrapped it over the sharp metal openings where the hooks catch. Then I put a little silicone grease on the inside of the hooks... Put back together...
VIOLA! Dead Quiet.. ;)
Guys,
This is a post that I made a long time ago about this same problem. I also tried adjusting crap with the door, never tried removing the door skin, but this will fix your problem. Here is my post:
Hello,
I feel your pain and know exactly what the problem is. The noise is coming from you weather stipping. Here are two of my posts from back in August. They describe the problem and how to fix it:
It is absolutely the weather strippings in the door seals. What you need to do is go to Wal-Mart and buy a can of STP silicone grease (blue can, red top, kind of like a spray paint can.) Pull your weather stripping off (driver and passanger side)...I am talking about the strip that runs along from the front fenders, up the windshield, and then across the edge of the roof, then down behind the rear doors. Wipe them off with a dry rag (to get the dirt off) and then SOAK both sides of them with that stuff. It is "greaseless" and odorless, so don't worry. When I say both sides, I mean the side you can physically see, and the side that actually touches the truck. (this is important) I had mine in the shop 3 times for that problem...and the truck sounded like a piece of s**t from day 1. I wanted to get rid of it because it sounded like it was 30 years old from all the noise the cab made. All the dealership did was spray the side you can see. After a year of living with the noise, I started thinking that maybe it was the backside of them. I soaked them, put them back on (real easy to do) and haven't had a problem since. That was like 3 months ago, but I'll do it every 2 weeks if necessary. It feels like I am driving a brand new truck, even though it is only 1 1/2 years old. Good luck, and I feel your pain!!!
And here is the 2nd post, in response to some questions:
It took all of about 10 minutes to do this. They pull off real easy...and putting them back on isn't too hard either. When putting them back on, start just above the windshield, and then slide it down behind the fender (be sure to note their position before taking them off and you'll see what I am talking about). Snap it back on along the windsheild, along the roof, then down behind the door. I am not mechanically savvy at all, and I am not a big fan of ripping things off, but it was very easy. I did it like 2 months ago, and I have had no problems with wind noise, leaks, or the strippings not staying on. I bought the GM dielectric grease, but I did not use it. The little tube was $14 from the dealership, and the can of silicone grease was really cheap at Wal-Mart. The way I figured out it was the strips making the noise was that I pulled them off and drove it around the block. It made my day...it was so quiet!!!!! Anyone that thinks their truck is a POS because of all the noise the cab makes needs to try this.
Guys,
Hello,
Do you / can you take a photo of this weatherstrip ? It would be much appreciated....
Thanks !!
  • 1 month later...
The driver's door on my 99 has been doing the same thing for the last few years. The door check has the spring on the inside of the door frame and a lack of grease at the S-shaped spring causes craking and also makes it hard to open and close the door easily.
A few years ago, GM issued a TSB on this problem. I took my truck to my dealer to get the problem resolved and gave them the TSB number. They looked at me like I wasn't supposed to know such things and said there were no reported problems with the check and spring.
So I go back home, called a friend who works for GM and he sent me a copy of the TSB. Took it back to the dealer and showed it to the service manager. Becasue my truck was out of warranty, I had to pay for getting the guide lubed but it never did fix the problem. The TSB called for replacing both the door check and the spring but my dealer said it wasn't necessary. Which was (of course) :banghead:
The only noise in the interior of my '00 Silverado is the sound of the stereo playing some tunes :cool:
Seriously, some of y'all are really nit picky on things. I don't think I've ever owned a vehicle that DIDN'T make noises. Even my girlfriends '05 TOYOTA TACOMA (supposedly the best trucks ever built according to C&D mag (insert sarcasm)) has several interior noises. It squeaks under the dash and makes a funny thump sound under the passenger floor. I told her to not worry about them and turn the stereo up.
If it's not a driveline noise, don't worry about it :banghead: But of course if its under warranty.... why not take it in??
I don't believe pictures are necessary - I would take some but do not have time to do it over the next few weeks while it would be light outside.
This also is not being nit-picky - I can deal with a noise or two. That is understandable. This noise is something that made my dad think it was raining outside because it is so loud. It only happens at slow speeds while as the body flexes - so parking, going up driveways, going over any bumps, etc.
Lube up the strips on both sides and you will be happy.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
