brakes pull to the left
hi,new to the forum,been reading on and off,
my 97 2wd has developed a brake pull to the left,
i've replace front brakes hoses,replaced front calipers,resufaced rotors,new pads,
bleed system, all of this and no change,
anybody have a direction i should try?
could abs hydraulic control unit cause the problem?
(i know bleeding requires tech1)
thanks for your responses in advance
Did you check to see if you have a loose wheel bearing? That could allow the wheel (and rotor) position to shift during braking.
bearing were checked when i pulled rotors to have turned,checked adjustment before removing, they were good
Use Google to search, it works a lot better than the gm-trucks search. In google, use something like
"site:gm-trucks.com brakes bleed pull"
