How can I keep rain out of my stake pockets?
I have a factory soft tonneau cover on my 2002 Denali and would like to plug the stake pockets in the plastic bed rail caps, did GM or anybody else make caps?
Thanks,
Dan
Thanks,
Dan
Get out the racing tape! :chevy:
Actually when I had my hard tonneau on my 95, I doubled up the insulation strip on the bedrail and covered the stake holes. I never had any water problems after that. Not sure if that'd work on the newer style trucks with the soft style. I dont see why it wouldnt though.
Nobody else has this problem? With the 11 inches of rain we have had in November I get 4 wet spots in my bed and would like to keep it dry so I can use it when I take my wife shopping, (I would rather drive my truck than her car).
Dan
Thanks,
Dan
The factory soft cover mounts inside the stake pockets and they are open.
Dan
I've got a some flush mounted stainless steel pop up cargo hooks that I bought at a Gander Mountain Sporting goods store in my stake pockets. I'd have to check the brand name on them but I bought them specifically because they are sealed and keep the water out. I have also found them handy for everything from tarping a load to helping secure motorcycles. If I remember correctly I spent @ 40 bucks for the four.
On ebay I bought black plastic inserts that fit tightly into the stake holes. I paid $11 for four of them. Can't remember the seller, but just look and you'll find them.
Rain the little that get in will only run down the inside of the box fenders and wash the dirt off. They also keep the areas dry so they wont rust.
Thanks,
Dan
Get out the racing tape! :)
Dan
Ah sorry, I thought the framework still sat on top of the rail and clamped to it, covering the stake holes. I havent looked at the newer ones though. Was recalling from older models.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
