2500HD vs 1500 Max Towing
I'm trying to figure out the best vehicle for towing 5000-10,000lbs trailers. A 1/2 ton can be configured to tow 10,000lbs, but with a 4.10 rear end and with the older 4-speed auto trani. The 2500HD will supposedly tow 9800lbs with a 3.73 rear end and the new 6-speed trani. (12,300 lbs with the 4.10). Even though the 2500HD is heavier, I'm betting that it will get better realistic gas mileage than the 1/2 ton due to the rear end and new trani. Or is it a mistake to go the 3.73 rear end instead of the 4.10? The Edmunds review of the 1/2 ton with the 4.10 showed average gas mileage of only 13.5mpg. Obviously it needs the new 6-speed trani., but the rear end makes a difference also, doesn't it?
We started out to purchase a 1/2 ton. But after checking stats, specs and pricing have decided that a 3/4 ton is more bang for the buck. With the Gas engine and 4.10 rear end on the extended cab 2500HD towing is rated at 12,400. We priced out a nice SLE2 configuration that invoices right at 35K with almost every option accept leather.
I just wish the truck had a larger fuel tank. I'm spoiled with the Excursion and it's 44 gallon tank. On the highway 850 miles between fill ups...:)
Towing anything bigger than a few snowmobiles, get a 2500HD. 1/2 tons are not built to tow equipment.
If you are getting into the 10,000 lb range, I would opt for the 2500HD. We all can assume that this fall, GM suv's and half tons will be equipped with the 6L90E, or some variation of it on the 5.3L and 4.8L motors, if you really want the 6 speed in a half ton. Hopfully, the Vortec Max package will resemble the Yukon Denali setup with the 6.2L and a 6 speed tranny. I am curious to see if GM adds the 6.2L to the HD's also, or even better, another big block. Right now your HP and TQ #'s are almost a wash (367HP and 375TQ in the half ton and 353HP and 373TQ in the 2500HD). With the gearing of the 6-speed auto you could even go for the 4.10's in the 2500HD. You have two overdrives, so you will get comperable fuel mileage and more low RPM launch with the lower first gear. I had a 99 silv 1/2 ton and towed 9,000 lbs through windy, hilly roads. It just felt like too much weight to be comfortable with. I have not driven or ridden in a GMT900 with the new 6.0L, but I have heard that is alot peppier than the 6.0L in the GMT 800's.
Thanks for the advice. I'd love to see the 6.2L in the 2500HD, but I need a truck this summer. I may go for the Duramax/Allison combo and quit worrying about it. It looks like you did the same. Have you been happy with that move?
I like big blocks for towing too.
The 2007 models (1500hd with 6.0 and 4.1) tow up to 10,500 lbs !!
My 2500hd 6.0 is 300hp @ 360 ftlbs (tows 10,200lbs)
Some are not accustomed to 3/4 ton p/u with 1/2 ton labels.
This is my second Duramax. I love them. There are still some 2500HD Classics on the lot with the LBZ. So far the LBZ is bulletproof. I would bet the LMM is just as good. GOBS of power. Pulls like a freight train and is just fun to drive because the power is just there. If you don't mind forking over the extra cash, I would not even consider the 6.0L. The DMax/Allison is the way to go for me. Don't let the "diesel justify" factor sway you. If you can afford it and you want it, buy it.
If you are regularly going to tow that load, go with the 2500HD. The 1500 with the Max Towing Pkg is only going to be a couple hundred dollars cheaper than a similar 6.0L 2500HD (the Duramax will run you another $7K, but you'll never have to worry about not having the stones to tow anything again) and you are basically pushing the limits of the 1500 constantly. If its only occasional towing, you may want the better ride the 1500 will give. Fuel mileage for the gas motors will probably be a wash with the 1/2-ton truck being lighter, but the 3/4-ton having the 6-speed.
If you go with the 2500HD, I'd get the 3.73 gears as you likely wouldn't benefit from the 4.10s (based on you trailer load) and it would just eat more gas.
I say go for the 2500. It's just beefier all around and will tow better. There isn't much difference in price either if you go with a gas engine. If you got the extra cash, a duramax would be even better. It's not cheap, but you would never regret it.
Like everyone else said, if you are planning on towing that load very often then go for the 2500HD. It is built stronger and has the 6-speed which may or may not give better mileage, but it will definitely be better for towing. It's not that the 1500 tanny is bad, it's just that having 6 gears for towing is better then 4 because the engine will be able to stay in the powerband more often.
............ I have not driven or ridden in a GMT900 with the new 6.0L, but I have heard that is alot peppier than the 6.0L in the GMT 800's.
I owned an 02-6.0-4:10, and just drove a new 6.0Max/4:10, and the max did not feel as powerful. Was ready to buy it that day too., but didn't. I think it was this new torque management software, cause when i stepped on it many times and under various conditions, it did different things from going good, to stumbling, to literally falling flat on it's face. I couldn't believe it, and the salesmans face kinda krinkled too. maybe i had a bad truck? but something tells me this new T.M. stuff is for the dogs, and is really hampering the 6.0Max's performance in the name of fuel savings. Big marketing beats me again! If they can do 16mpg they will sell another 100K units or so, but us guys who want to pay for performance suffer for the masses. I'm sick :cheers:.
  • 4 weeks later...
I just bougth a 2500 HD and specificall looked for the 4.10...is does make a difference. I traded a Ford V10 and it had a 4.10....would not go any taller than a 4.10 myself, and it does not make too much difference in mpg...
Think of it this way. If you buy a 2500HD and change your mind about what you tow, or you suddenly decide a 5th wheel isn't that bad, your 2500 will do it. It will tow 14,800 on the bed (Models vary a litle bit depending on 4wd vs 2wd, etc.) If you buy a 1500 and change your mind, you need a new truck. The purchase of a 2500 means you don't have to worry about changing your mind. You'll be set no matter what you decide to do. It's the same issue with 2WD vs 4WD. Sure, you might not need it, usually, but if suddenly you do, it's there waiting for you. To some extent buying up from your present requirements is buying peace of mind.
I also looked long and hard at the 1/2T MAX tow pkg but did not see the value added. It is just about the same price as my 3/4T. I also noticed that the engine is not the same one as in the 3/4T and the new 6sp tranny sounded too good to pass up. So I ordered a new 2500HD with 4.10 rear end and have been very happy with the results so far. I tow a 5600lb travel trailer and have had no regrets. The low first gear allows me to get the load moving with ease and once I reach hy speed it can maintain 60 in 6th on the flat and usually downshifts no further than 4th on a local 6-7% grade - while maintaing 60 MPH. I debated the 3.73 vs 4.10 rear end as I was on the borderline with my load. I opted for the 4.10 due to the number and size of hills and grades I encounter around here.
Randy, I'm with you on this one. I look at the $40,000 and $45,000 half-ton rigs on the Chevy lot and wonder why a guy would buy one of these when he could have a 2500HD for the same price, or very little more. For me, at least, the HD is the far better value.
Love my DMax, but the way.
Steve
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
