07 Sierra Fog Light Upgrade Question
Hi I noticed on some other post that you can upgrade your foglight with a little alterations with 9005 bulbs. They are 60w bulbs. On my 03 silverado the stock bulbs were a h10 or 9145 bulb. it is close to the 9005 bulb but is only a 45 watt bulb. it uses the same connector as the 9005.
So my question is will a bulb that has a 90degree bend work with this upgrade?
I might do this route just to be safe not to burn up my housing and to save on coming traffic from getting blind.
Also you just had to trim the bulb not the housing right?
I did the foglight upgrade and I used philips crystal vision 9005 bulbs. They are at a 90 degree angle and they are fine. I think y some 9005's are straight and some are 90 is to help fit better. As for trimming, u have to trim the bulb not the fog light housing.
FYI, I checked my fog light housings again yesterday and their integrity is still in tact. I know there have been issues with this upgrade in the Yukons (about 2" smaller housing) but have heard nothing negative from anyone who has done this to their GMT900 trucks. The fog lights are able to be aimed so don't worry about blinding people.
Daddy
I know that there will be nothing wrong with the 9005 bulbs in the housing but I am going to be safe and use the 9145 bulbs for now. They are 45 watts so it is a 21 watt improvement so it will help. Anything will help now because the stock bulbs suck!!!!!
Daddy
whats the procedure for aiming the fog lights, I looked through my owners manual multiple times and they dont cover anything about the bulb or aiming them. mine are useless as they point down too far.
Daddy
You have to get under your truck, remove the harness, and then release the housing from the truck. On the back, one of the studs has an adjuster. As soon as you see it, you'll understand.
You can see the adjuster in this picture:
Daddy
Daddy
Daddy
Thanks, I will take a look at it and do some adjusting.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
