Who needs Zaino???
Well, I got home about 6 tonight and since it was about 70 out I pulled the car up by the garage in the shade and gave it a good wash job.  Only stuff we had laying around is some el cheapo junk (gotta go to the store for some more meguaires) but here's some pics of it, she shines up quite nicely:
I really wish it was legal to run around w/o a front plate, the car looks so much better w/ the pontiac cover on it.
My underhood *bling bling* gold paint job on the fender braces and engine mounts
The "grand prix" decals I added to the side a month ago, I'm gonna take off the GTP emblems from the doors and just leave it like that for a cleaner look.  And also, people won't know what they're up against in a race.
The rest of the pics are up at:
http://www.blackandgoldgtp.com/images/july_23/
I'll have some more pics in a few days that I promised a while ago, but I just got my camera back last night.  I'm gonna swing by one of my friends houses tomorrow night (weather permitting) and get some shots of her w/ the car.  And no, it won't be me in a wig, despite that's what everyone is expecting.
Was that just a wash or did you wax it too? I spent 3 hours washing (zymol), waxing (meguires), and then polishing with maguires 7, my black silverado today. I didn't look half a shiny as the grand prix. What gives? Any suggestions?
except, tint those windows, would look so much better :D
no kidding, I'm trying to scrape together 200 bucks for window tinting and another 100 or so to get some dual chrome exhaust tips installed.
JR, I Just used Turtle wax car wash, only spent about an hour in all to clean it and dry it.  I did take off the grilles and sprayed them w/ a few coats of gloss black since the plastic was looking weather beaten and turning a bit white in spots.  I didn't wax it afterwards.  When I washed it, I did it in the shade and it was 70 out so the water didn't dry quickly, which allowed me to towel dry it and buff it a bit by hand w/ some towels.  I seem to get the same results w/ any kind of car wash.
I rode in one of my friends GTP(99) the other day.....omg.....I WANT ONE!!!!!!!!!!!!!!!   The MPH on the windshield is soooo schweeet!  I love hearing the boost kick in too heh heh.  His is red, one fun ride.  I better stick to my slow truck thou, I'd speed to much in one of those cars....they are schweet though.  I love black btw, cept the fact that you can see dust on it 3 huors after washing it....
Yeah, the power is the only reason I can overlook the fact that it's a car, not to mention all the nifty features like the HUD and the info center.
Mine actually will stay relatively clean for days since it get's parked underground at work and in the garage at home.  So long as it doesn't rain and get covered in waterspots I can go for a few weeks between washes.
Looks good Jon.  :D I really need to wash the truck, it has been over 4 months since I last washed it and after some off roading over the weekend, it is more gray then sunset orange.  I will have to get a pic of it one of these day.
BTW, I think your crazy, shorts when it is 70s degrees outside, thats just plain freezing...lol.  I think its the 110 - 118 degree weather here, we actually had a low temp the other day of 78 and I had chills.  95 sounds cold.  ugh... ???
c'mon, it wasn't too bad out in the sun w/ shorts on, but let me tell you, when I was washing the car in the shade and the overspray hit me I was cold.  We've had temps about 100 for the past few days so this has been a much deserved break.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
