I Finally Found And Corrected My Rattle.
Since I bought my truck with the 5.3L, it has had an annoying rattle that is only there when it's in 4 cylinder mode and under very light acceleration. It kind of sounds like a helicopter fluttering. I knew it was from underneath about midway towards the front. That is the only complaint I've ever had with this most excellent truck.
After washing it today I thought I would crawl under and have a look see. I found that there is a shield on the passenger side of the transmission that has 2 bolts holding it on to the side of the tranny. I think it's there to keep the heat off of the tranny because the exhaust pipe is right beside it. It is too close to the tranny pan and under the right harmonics it resonates against the tranny. I simply bent it away fron the tranny from front to back, only bent it enough so that it wouldn't touch the tranny, and now the noise is gone. I can't believe I'm alone in having this noise as they are all alike I'm assuming.
Interesting. I haven't had this noise, but I'm sure other have experienced it. If I ever hear such a noise, at least I'll know where to look first. Thanks.
-Al
You are not alone Bob. I feel your pain. I too have experienced the flutter you speak of but have been too shy to bring it up. I admire your courage in admitting this publicly. :banghead: Just kiddin'.
Really, I've noticed the flutter and thought that it was the nature of the beast. I do feel this harmonic in my accelerator foot, not sure if it is the tranny hump or the pedal. Your discovery seems to confirm a correlation of that area. I'm enjoying a couple of cocktails this evening, but tomorrow I'm going to roll underneath Silvia and check that out. That flutter, though slight, is the only way I know that the V4 mode is operating outside of the DIC (almost the worst possible choice of an acronym.) Your sleuthing is greatly appreciated.
It's been making me flutter since I drove it off the lot. :banghead:
I, too, have been severely annoyed by this AFM flutter/vibration on my 2008 Sierra.
I will be crawling under the truck in the morning, and post info here.
thanks for the info !!
Hmmmmm.....mine won't "accelerate" the least bit in v4 mode...it kicks out at the slightest throttle touch or hill. All is seamless.
Same here. If not for the DIC, I would never know I have AFM, it is 100% seamless and undetectable. And the ONLY time it's on is when I am decelerating or cruising constant speed on the freeway with no load, incline or headwind and I am under 65 mph. Heck, once when I was on a flat freeway cruising 60 mph, it was in 4 cyl mode, I turned on the A/C and it kicked into V8 mode. :banghead:
I'll kick you into v8 mode.
Creeped under mine this AM. Bumped on it and didn't notice a rattle or anything. It was pretty close to the tranny case on the engine end and I tweaked it out slightly, maybe 1/8". Exceptionally stiff for a heat shield. I'll try to pay close attention for any change in sound today.
Ran some errands and worked out a nice interstate leg on the trip. Very difficult to tell when V4/V8 switches were made. Sometimes I thought it had and it hadn't! :banghead: The heavy gauge of the tranny heat shield must have been responsible for the lower frequency "flutter," thinner sheet metal would generally resonate at a higher pitch. Harmonics might be the very reason for the heavier gauge. I'm sure GM wouldn't have spent an extra 57 cents if it had not been necessary.
That's what I thought, very thin and flexible. Easily bent also. I squeezed and released and when it first sprang back into position it gave the flutter noise just sitting there. Made me a pretty happy guy after that.
  • 3 months later...
Hi RVJ: I'm having a drone or hum noise too and sometimes a slight vibration in the gas pedal/floorboard. Maybe your post is a solution for me! I have couple questions though....
When you bent the shield, did you bend it towards the exhaust pipe or towards the tranny pan?
Can you explain more in detail what exactly and how you bent it? thanks for your help!
I get the same feeling in the gas pedal. I chalked it up to a quirk of AFM with the engine struggling while only running 4 cylinders right before switching to V8 mode. Although I've only noticed it under heavy load in V4 load, not light as the others have found with the heat shield.
I also found the black motor cover was vibrating on a small wire loom. A couple holes and wire ties silenced in up nicely. I mainly noticed mune at about 45 mph in v4 mode and when accelerating slightly and going into v8 mode. It's all quite now. :lol:
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
