new inline 6
I was just wondering when the 4200 inline 6 will be in the 1500.
Also, I think some time ago some was asking what they thought about the Avalanche.
Well I have only seen two on the road (one white & one blue) I like the front view (the lights, grille & bumper/valance). I really didn't like the profile. The fenders are to squared off.
No offence to the Avalanche owners, just my 2 cents.
I would also like to see the inline 6 in a 1500. Just think of the room under the hood. Can you say "Turbo" or "Blower"?! I thought I saw a thing in AutoWeek that it will be offerd in the 2003 GMC's
I've heard a little about the new straight sixes, but y'all probably know more so here's some questions for you:
What kind of gas mileage do they expect compared to the 4.3L V6?
What are the HP and torque numbers for the Trailblazers w/ I6?
What is the block made of?
I also would like to know when I can get one in a pickup.
16 *Est* City, 21 *Est* Hwy
SAE Net Horsepower, 270 @ 6000
SAE Net Torque (lb ft), 275 @ 3600
 Aluminum.
  Is it OK to scan the HP/Torque chart from the brochure and post it here? It has a nice flat torque curve. The brochure claims 90% of peak torque is available from 1600 rpm to 5600 rpm. :)
I won't tell if you won't...j/k I don't think that's a problem.  Thanks for the info I guess I coulda looked it up myself.
My dealer told me that he read that possibly GM was planning to build a new V6 using the 4.8/5.3L block with 2 missing cylinders along with the 4200 I6 rumor.
Anyone heard anything about this?
It would be cheaper for GM, I would think.  Since the old 4.3L had 55hp and 70ft/lbs of torque less, I would guess a V6 would have somewhere around 240-250hp and same torque as currently.
i know Gm has a new line of V6 engines coming out, but i'm not sure where they come from. One is a V6 with over 300 HP!!!!!
These are the specs for the "new" v6's GM is planning:
3.2L Turbo DOHC V-6, 321hp@5500rpm and 364lb-ft@2000rpm
3.8L DOHC V-6 251hp@6000rpm, 263lb-ft@3000rpm
3.2L Turbo DOHC V-6 253hp5500rpm, 261lb-ft@1750rpm
2.8L Turbo DOHC V-6 290hp@5500rpm, 297lb-ft@2000rpm
The primary developement of these motors were done for the new Caddy CTS.
I wonder if the 4.2 Vortec I6 would even fit in the engine bay of a new Silverado?  I looked at one in a Trailblazer, and it didn't appear all that big, but then again the Tralblazer was designed for a I6 motor.  Ever wonder why Ford and GM don't have an I6 diesel motor in the 3/4 ton and up pickups?  Its because the inline motor is too long for the engine bay, and still provide a reasonable sized radiator.  Of course the Dodge is designed for the Cummins, so it fits in there.
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
