I just replaced mine on my 2006 sierra also...it is at the end of the fuel tank towards the front of the truck...you have to relocate the breather canister when you replace it...if you need more info let me know I just went through the same thing....I am new at this forum also so I hope you are better than me at navigating through this and send me a message...
is it easy to replace
Just wanted to give this thread another thumbs up. :( I have a 2006 GMC Sierra Crew Cab Z71 and was getting codes P0449 and P0455. Replace my canister with ACDELCO 2142149 from Rock Auto (less than $20), along with some rubber heater hose and clips (less than $5). Installation was easy and the check engine light turned off the next day.
Thanks for the great info. :P
Just wanted to post and say "Thanks" to odayflor and everyone who contributed info on the repair for code po449, at least it did work for my truck!!
I went to my local Advance Auto Parts and bought the AC Delco part # 214-2149 which is the same exact part that was originally on my '06 1500 crewcab!
Cost for the solenoid was $23, plus the piece of heater hose & 2 clamps.
Guess I'm curious as to why GM wants to "update" with remote filter, what is the advantage of it?
Funny thing too, after completing the swap of the solenoid, started up the truck, rolled it down the ramps , let it run for a few minutes to move the ramps out of the way and got back into the truck to park it, the engine light was off and has been ever since!!
Again, thanks for the help!! :thumbs:
WELCOME!!!!!!!!]
Just wanted to give this thread another thumbs up. :driving: I have a 2006 GMC Sierra Crew Cab Z71 and was getting codes P0449 and P0455. Replace my canister with ACDELCO 2142149 from Rock Auto (less than $20), along with some rubber heater hose and clips (less than $5). Installation was easy and the check engine light turned off the next day.
Thanks for the great info. :)
Ian -
I have the '06 Chevy version of your truck (crew cab Z71) - but I can't seem to locate the canister. I've looked at the pics that have been posted here - crawled under the truck yesterday (it's cold in Indy right now) but no luck. Where was it located on your truck? I think if I can physically "see" it, life will be a bit simpler from there. Hopefully it isn't mounted somewhere on top of the tank?
Thanks in advance.
WELCOME!!!!!! Glad it helped....Although not a single GM employee agrees with us on this
Thanks to everyone here i have ordered the part. I will let you know if it works on my truck as well.
I have an 06 crew cab. once i order the part how do I know where to run the hoses? everyone is talking about purchasing the extra hose but where the hell does it go? lol did i miss a post?
I have a 1999 sierra 5.3 and this vent valve fit on without any trouble at all. even the stock hose fit right up...only thing was because this valve is a bit bigger the bracket needed a slight tweek (just bend it a bit).
Don't think twice about using this part number...it's a no brainer fit.
Hi guys, Im new to the site. My engine light came on this morning and coded p0449. Im hoping the AC Delco part will work on my 03 Silverado 4.8? Can you guys help me out? 1500 4x4 reg. cab. Thanks.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
