Another Newbie (from So. Cal.)
Hi all,I thought I'd introduce myself and complement you on your excellent website.I was able to fix my front axle actuator with the knowledge from this forum.
My main ride is a '95 K2500 Chevy Suburban with which I tow our toy hauller to the desert in California City,Ca.
We also have a '99 K1500 GMC Suburban(wife's ride) all stock except for nice whells and tires,anyway good to be a member.
here are a few pics of my toys....
Welcome to the forum, and thanks for the pictures. They all look great, and nice trailer. That is great.
Cheers.
The 95 looks great. Welcome.
I still have my '95 C1500 (great for the dump) and it runs great.
Just to early to start using the 08 for shoveling rocks, gravel, trimmings, etc.
I know I'll get there. Just takes a bit of time. :banghead:
I know I'll get there. Just takes a bit of time. :D
After doing some deep thinking I realized I didn't want to tow the toy hauler with my wife's '99,mainly 'cause it was borderline maxed out for towing the weight(approx. 7,000lbs.)safely,but also because it's almost showroom condition when I got it earlier this year.So I looked around on the 'net and found the '95 in Ventura.The '99 was a little rough at first but a few trips to our local Pick-A-Part for few good reusable things has it like it is now,very nice for a burb with 210,000 miles on it.
Funny thing happened last nite,one of the local young guys rolled his Ford Ranger(and totaled it)on a local dirt road and came to me for some help.So we,my wife included,went to help this dumba__ out.I got to use my newly installed winch and drug(sp.?)out.The big 'ol burb pulled it like it was a toy.
The bottom line I suppose is the '95 burb does exactly what it was built for and does it well.The '99 does it well too,quiet and comfy.My wife says she love it.
Here are a couple of pics of the Ranger
see ya later,Gary
:lol::sigh::drool: I couldnt figure out where I had seen your Suburban before......Then it hit me. You have 2 welcome posts! Jeesh, now I know I need coffee!
Welcome! (Again) :D Beautiful truck!
Welcome to the site! Cool rides. Tell us about your avatar. Is that your car?
It was.That's an old picture I have on a 35mm slide.I bought it in 1969,drove it until 1973 at which time I bought a brand new 1973 Chevy Vega Camback GT(the engine was junk but the thing handled great)The car is a 1966 Buick Skylark GS,401 nailhead engine,Borg-Warner T-10 tranny,Hurst shifter and posi rear end.It's hard to tell but it was fire engine red,black interior w/bucket seats.I tought my wife(still married to this day)how to drive a stick with that car....I sure do miss it.I was stationed in Long Beach,Ca.(US Navy) at the time
g'dirt
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
