When Did You Change Factory Diff Oil?
Just wondering as I am approaching 2K miles on the Sierra and have thought about changing the differential oil in the axles around the 5K range to clean out any break in particles and I also like to install a magnet inside the cover.
I've always been amazed how much break in wear occurs with new gears. I regeared my Jeep TJ to 4.88s back in 02 and after 500 miles was amazed at the break in wear particles. I also rebuild Mercruiser boat lower units and notice it with them. I changed out the factory oil in my 7.5" 10 bolt in the SS at around 3K miles and noticed a good bit of metallic break in particles.
I know it might be anal, I just think it's good to get the initial amount of wear particles out and clean fluid inside.
Thoughts?
On a brand new vehicle, I change it out after 1K miles. After that every 50K. Never had any problems. A funny thing is though, in both my trucks owners manuals it goes through all the maintenance require for 150K and not once does it say to change the gear oil. :fume: It just says to check and top off as needed every 25K. Weird. :crackup:
That's a good question.
In fact I asked a similar question (but I added the tranny and T-case) on another GM/Chevy site and was told to just wait until the manual says, which is 50K. My last truck I didn't change the tranny and diff until 60k and I added another 75k trouble free miles after.
And GM uses syn oil in the tranny from the factory so maybe I'll wait. But who knows, I'm dying to change each to syn, like Royal Purple.
+1 :fume:
I have changed the rear diff in all of my new trucks at the 1k mark. In addition to removing all of the break-in particles, I noticed that my fuel economy seems to be higher than other trucks of the same year/model :crackup:
50K on severe duty
never on normal duty.
Never had a problem on both. If you have the time and money to do it...go for it, I would.
I change mine at 5k miles. It is very surprising how much crap comes out. I have done this on four different vehicles with good success. Changed to Amsoil syn gear lube, greet stuff!
I remember back when I bought my 99, the service manager said to change the rear diff oil at 5K miles, and after that no need to change again unless it was on the severe duty schedule.
When I bought my 08, the service manager didn't say anything about a early rear diff change. The truck only has 2K miles on it now and I will probably have the fluid changed soon at the shop where I work and can get it done for half the cost of a dealership charge.
I usually change it around 5k. There is a LOT of metal floating around in there after the gears break-in. And for those who think it's not needed, remember that your axle bearings are sharing that oil with the gears.....
I changed mine (2004 Silverado) at 85,000 miles (before I towed a 6600 boat from DE to Corpus Cristi TX). There was a magnet built into the cover (had some gum/junk on it, I cleaned it off). I used Valvoline SynPower 75w90 fluid, it meets the neccssary GM standards. (I can't remember the numeric code, but at the time I called and emailed Valvoline with the standard and they named their product that fit).
I didn't expect many people to have changed their fluids so early on. I thought I was the only anal maintenance person here. I plan on changing mine here soon and using Mobil 1 75W90 Syn.
What fluid does the 8.625" 10bolt G80 locker like the best? Synthetic ok?
I always have had great success with M1 Syn 75W-90 from boat outdrives to heavily offroaded Jeeps diffs.
Um, you are on a forum in which guys actually take care of their rides vs beating the hell out of em..
Your truck came with synthetic gear oil in it. M1 is fine and the Eaton G-80 locker does NOT require an additive.
Have a good one, :fume:
Don
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
