The New Addition!
Well, I don't think I need to type much :rollin:
2007 Yukon Denali, 18K on the clock..all options that I am aware of except for the nav system. No biggie.
Very nice. I'd love to one day own a Denali...it's going to be a few years though. Probably about 30! :rollin:
It is quite a machine. :D
Congratulations there Blake on the new addition to the family! :rollin: A really good looking addition to the family at that!
Congratulations there Blake on the new addition to the family! :lol: A really good looking addition to the family at that!
+1 :rollin::D
Very nice indeed. I bet it drives like a dream, and the colour you chose is great. I really like it. Congrats.
Ahhh......I don't like it :D
JUST KIDDING :lol: Thats actually my favorite color on those things!! :rollin:
That is one sweet ride!!!........from the front clip back anyway. :D Sorry, never liked the front end of the GMT900 Yukons. But the rest of that truck is :rollin:
:rollin: Nice Dude, it looks very Happy! :D Do you got something to cover it, so those trees don't piss on it?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
